Old 13th November 2011, 09:24 PM   #1
tmblack is offline tmblack  United Kingdom
Default DIY Pinch Rollers
Since this is diyaudio, I though I try to rebuild my tape recorder's pinch roller.
These things are also obsolete so finding one would be nearly impossible.
Does anyone know how to make the tire compound?
Old 13th November 2011, 09:41 PM   #2
kevinkr's Avatar
This I suspect would be a near hopeless diy venture, but there are outfits like Terry's rubber rollers that rebuilds tape recorder pinch rollers and turntable idlers.. Here: Terry's Rubber Pinch Rollers & Wheels
www.kta-hifi.net
Old 14th November 2011, 08:21 AM   #3
It would be extremely difficult to mould a new pinch roller with satisfactory results, problems with consistency of hardnes and concentricity for instance. An alternative approach might be to approach a company that does typewriter platten (If any still exist) and see if they have anything of a similar diameter which you could fit onto the original inner and turn to size. It is possible to turn pinch rollers on an ordinary lathe with a sharp tool if you freeze the rubber first and "top up" with freezer spray while machining.
Old 14th November 2011, 09:30 AM   #4
One thing going for you is that pich roller diameter isn't critical. Rather than trying to make the soft part yourself, why not go the other way and try to find some off-the-shelf rubber bushing and fabricate the metal center put of aluminum or brass using a small lathe?
I wonder if urethane would make a good pinch roller? It would certainly be more durable than rubber. I'm sure that there are lots of runner and urethane bushings out there that might be adapted to this use.
Peter Hansen
www.audio.thesonicboomers.com
Old 14th November 2011, 10:57 AM   #5
blakkshepeaudio's Avatar
+1
And urethane turns like a beauty as long as your tools are SHARP!
Watch out for the grade / hardness though - too hard and the tape may slip.
Ode to Tube Rollers CoolBlueGlow Tubes / Valves 20 20th September 2011 07:44 AM
integrated rollers geoffrod Construction Tips 4 8th August 2011 08:17 PM
clean your pinch roller... with gasoline! Sir Trefor Analogue Source 3 17th May 2005 04:39 AM
who reconditions rubber rollers?!?!?! hi_im_sean Analogue Source 4 25th April 2005 05:37 PM
Page generated in 0.07953 seconds (75.66% PHP - 24.34% MySQL) with 10 queries
