| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
My moving coil cartridge output is .4mv . I am able to change the cartridge loading resistor in the phono stage in my hybrid vacuum tube preamp( There are instructions for doing so). The instruction for the cartridge says to use a 20 ohms if using a transformer and 100 ohms if using a headamp. I will not be using either but connecting direct to the phono input on the preamp Do I remove the default 47k resistor in the preamp and use the 100 ohms resistors?
#2 |
No, load resistor is for you MC pre-pre or MC preamp, you can't remove the 47K MM load resistor. I mind you need a pre-pre 17.5 dBs gain or a step-up 1:7.5 to achieve 3.0 mV need for your MM phono preamp.
#3 |
The gain will probably be insufficient for direct use with your new cartridge unless your phono stage has a gain of 70dB or more.
www.kta-hifi.net |
#4 |
The gain from phono input to main is 67db.The preamp manual (ARC SP9mk2)states that 47k is wired in for most high-output moving coil or moving magnet cartridges. The cartridge specs (ATOC9) call for 20 ohms recommended load impedance. The preamp manual also recommends using the appropriate value (extra resistors provided ) and illustrates how to solder the resistors on a part of the circuit board for the match. So assuming I did not have a phono input stage ..to boost the MC output I could do it with a transformer or a "headamp"..so this is where I am a bit confused..is the phone stage of my preamp then a headamp? If so the cartridge manufacturer recommends 100 ohms load.
#5 | |
When I referred to the gain required in the phono stage I was referring to that of the phono stage only, it may be that if the SP9 phono stage is sufficiently quiet and if the power amp sensitivity for full power is 1Vrms or less you have more than sufficient gain available as things stand. So the first thing to try is adding a shunt resistor as mentioned in the manual - in this case I would start with 100 ohms and see if you have sufficient gain and an acceptable noise floor. You may find that you do not have quite enough gain or the noise levels are a bit excessive in which case either a step up transformer or head amp is indicated. (Personally I prefer transformers with my 200uV SPU GM E II and use Lundahl LL1941s, the rest of my hardware is my own diy stuff.) You'll have to try it and see how it works out. Generally I would suggest additional gain ahead of the phono stage for any cartridge with an output of <1mV @ 5cm/sec lateral recorded velocity.
www.kta-hifi.net |
#6 |
Ok I will do that in the morning and report back...I suppose then that I should remove the stock 47k and put the 100 ohms in place...thanks
#7 |
No don't remove the 47K, just put the extra resistor in parallel with it. Bear in mind that in some cases (I am not familiar with the SP9) there will not be a physical 47K anyway, but this will be made up by other resistors etc. You just want your resistor in parallel with the input, on the cartridge side of any DC blocking cap.
#8 |
#9 |
Ok everyone ..here is the circuit and res. connection ..for one channel phono section ARC SP9 mk2
R1 is 54.9 ohms R2 is 49.9 k RC is variable (here is where I would add the appropriate vale ) C36 is .560 pf...the manual says not to remove these Also DF96 I believe you are right regarding the 47ks and will probably do as you suggest regards Last edited by apaulr; 7th November 2011 at 01:38 PM. |
#10 |
You could put a 100 ohm resistor in parallel with the 47K and try it. You probably won't have enough gain and won't be able to turn the volume control up far enough to get to listening volume, and if you do, you might have too much noise. In fact, you could just plug it together as is - just the 47K - and see if you have enough gain and low enough noise. Your preamp probably expects on the order of 4mv.
If not, you can either use some MC step-up transformers or a MC pre-preamp which will give you enough signal to drive the MM phono input. Jim |
| Cartridge loading | MiiB | Analogue Source | 0 | 27th May 2011 10:12 AM |
| 'fet as resistor' for cartridge loading? | Onvinyl | Analogue Source | 1 | 4th February 2006 03:08 PM |
| Shelter cartridge loading | Frank McCrea | Analogue Source | 1 | 18th November 2004 04:51 PM |
| MM Cartridge loading question | gurevise | Analogue Source | 7 | 16th December 2003 12:30 PM |
| Cartridge Loading | vpharris | Analogue Source | 2 | 9th July 2002 03:40 PM |
| Page generated in 0.11108 seconds (76.01% PHP - 23.99% MySQL) with 11 queries |
