| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#11 |
I put in the 100 ohms and I was surprised that I had enough gain. I was able to rotate to the 11-12 o'clock position with a comfortable listening level. Beyond that it started to get real loud...then again my listening space is not large. The noise floor is excellent. I think I can live with that. Thanks for the options.
#12 |
Wich sensibility have your loudspeakers?
#13 |
I am not sure of the sensitivity , nevertheless the speakers are Thiels CS3.5.and I use one of two amps at a time ..Adcom GFA 555 or a MCintosh MC2105...regards
#14 |
As per Stereophile archive Thiel CS3.5 have 88dB/W/m, MCIntosh 105W 4 ohms, Adcom GFA 555 325W 4 ohms, small listening space can help.
#15 |
Thank you for the follow up..I appreciate it !
#16 |
For MM load input Salas moderator suggest to put a 100K trimmer instead the fixed 47K load resistor to trimm by hear best result & after change for a very high quality fixed resistor.
#17 | |
www.kta-hifi.net |
#18 |
Especially the MC 2105...very sensitive
| Cartridge loading | MiiB | Analogue Source | 0 | 27th May 2011 10:12 AM |
| 'fet as resistor' for cartridge loading? | Onvinyl | Analogue Source | 1 | 4th February 2006 03:08 PM |
| Shelter cartridge loading | Frank McCrea | Analogue Source | 1 | 18th November 2004 04:51 PM |
| MM Cartridge loading question | gurevise | Analogue Source | 7 | 16th December 2003 12:30 PM |
| Cartridge Loading | vpharris | Analogue Source | 2 | 9th July 2002 03:40 PM |
| Page generated in 0.08578 seconds (74.03% PHP - 25.97% MySQL) with 11 queries |
