Old 11th October 2011, 06:27 PM   #1
tmblack is offline tmblack  United Kingdom
Default Tape Deck Motors
Looking to speed up the motor on a cassette tape deck.
Anyone know what sort of motors are used commonly?
I know the reel to reel often used AC synchronous motors and some are DC direct drive units.
Old 11th October 2011, 06:38 PM   #2
Mooly's Avatar
Well there are many types... but usually simple DC motors in most decks.
Speed control varies.
Many motors have a preset pot on the rear of the housing and achieve speed control by sensing back emf from the motor and have a small regulator pcb built in. These are the most common and fitted on anything from a cheap portable to quite expensive decks.
Similar are motors that incorporate an FG (frequency generator) and have a small control IC built in. These are physically the same size as the above type.
An older variation is a motor with a mechanical governor, again these look the same as the above. Speed control achieved by three sprung weights that when the speed is correct they move outward and break the current to the appropriate armature winding. Often seen in 80's car stereos and have tremendous torque maintaining speed under load.
Other than those there are the dedicated manufacturer specific motors seen on expensive decks. Often a direct drive capstan an an assortment of reel motors.
A simulation free zone. Design it, build it, test it.
Old 11th October 2011, 07:49 PM   #3
That's interesting. The preset pot must be the simplest to change. I want to double the speed.
Old 12th October 2011, 06:36 AM   #4
Mooly's Avatar
Depends entirely on the motor. You may have to alter component values on the motor regulator PCB (assuming that type).
These things used to be 10 a penny, hard to find now. This is a typical circuit that would be built into the motor housing.
12V DC motor for Cassette tape speed control -Automotive -Electronic Circuits Diagram-Elecpod
FS: Sony TC-777 parts... motors, tape heads etc. honinbou Swap Meet 0 4th January 2009 07:19 AM
fixing a tape deck stephen Bishop Parts 12 9th November 2006 01:33 PM
Tape DECK Switching iiv2003 Analogue Source 1 11th September 2004 11:01 PM
malfunctionning tape deck Daniel-A Everything Else 1 14th May 2004 12:09 AM
GC for tape deck use? dine1967 Chip Amps 2 11th May 2004 01:42 PM
Page generated in 0.07316 seconds (73.01% PHP - 26.99% MySQL) with 10 queries
