I'm new, What phono pre do you recommend?
Hello,
I've been a member for a while, but I'm still new at this. I've been honing my skills and getting ready for my first real from scratch DIY project. Now that I'm ready, I need some advice. I would like to build a phono pre with extremely low noise and excellent sound reproduction, so I have been considering a battery powered design. My problem is I don't know what design to use, or what designers are well regarded, or how to tell that a design will very clean and accurate. Here are the designs that I have been considering in no particular order:
inDiscreet Phono Pre-amplifier [English]
DIYHiFi.org • View topic - "Duplex" 2SK369 MM phono preamp
Boozhound Laboratories JFET Phono Preamp Kit
I'v also been looking at this one but with an external power supply.
Hi-Fi RIAA Phono Preamp
I am leaning toward the indiscreet phono pre simply because the guy seems to know what he is talking about and he's not selling anything so he's not going to try to talk up his design, but of course that's not the best basis for a decision.
Has anyone here done any of these projects?
I would love to hear what anyone has to say about any of these projects.
The first two uses passive equalisation. Some audiophiles will swear that it is better. Hard to tell though.
The first circuit uses a off-set power supply which may be difficult to realize using batteries and the the discharge of the batteries may not be equal thus may affect the performance during longer listening periods.
Rod Elliot does not publish bad schematics and it may be a lot easier to build and get repeatable results.
I have not encountered any circuits from Boozehound, but judging from what he offers, it seems like he knows what he is doing.
Good luck,
Nico
Good luck,
Nico
Thanks for the advice. After your response, and after hearing from Rod Elliott via email about the possibility of using batteries, I am now leaning more towards his design with a separated mains power supply. I guess i have never heard a phono pre that runs off mains power and is totally silent, but then again, I have never heard a phono pre with a separated power supply. Right now I am using the MM phono stage of my Yamaha C-4, and it is quite good, but when the volume is high I can still hear (very faintly) a hiss form the amp. I'm hoping this project will eliminate that. Do you think it will?
Any more advice regarding phono pres that you can give is welcomed.
if the Yamaha is a bit too noisy for You, all the other circuits won´t probabely any better.
A differential amplifier as frontend for example has higher intrinsic noise than a single ended or complementary stage. Additionally the differential stage of the inDiscreet lacks in symmetry, thereby giving rise to distortion.
The local feedback degeneration resistors R4/5 are of high value and increase noise considerably. Passive equalization asks for higher gains which has to be considered regarding noise and distortion figures.
The noise issue of large emitter-/source-resistors also applies to the Boozhound. A bit weird that both gain stages of the Boozhound are identical. It is rather common standard to have the most gain in the first stage.
The Duplex is imho superior in noise performance compared to the former two stages, as the resistor value niveau is generally lower.
Like the Boozhound it requires just one supply rail.
The two stage OPamp design uses Opamps of unsuffiecient performance.
As a rule of thumb the noise spec of the op amp should be lower than app 5nV/sqr(Hz) for MM-pickups which the outdated TLs clearly miss.
If I had to choose the Duplex would be the most interesting circuit of the four.
jauu
Calvin
No it won't. Any RIAA stage will have treble hiss compared to the other line
inputs, it is inevitable, and in a decent design far lower than groove noise.
(With non-optimum grounding also more hum, but that can be fixed.)
I don't think you have a hope in hell as a first project of bettering the C4
phono stage, with its MC input, double MM inputs and loading options.
Spend you time and effort elsewhere, What's your turntable/arm/cartridge ?
rgds, sreten.
I admit I've never heard the C4, but I'll wager my "first time project" Pass Pearl sounds at least as good (if not better) than the MM Yamaha stage. I'd love to do a comparison, but certainly not going out of my way to find a C4.
jeff
jeff
It might, but its a one input medium MC stage, its very inflexible compared
to the C4, and without knowing the source (MM), completely inappropriate.
There is no evidence at all the C4 phono stage is the most limiting factor.
rgds, sreten.
The C4 in todays money is a circa $2.5K preamp, with serious phono stages,
as its the right sort of vintage where they were the most important input.
Actually, it's very flexible, and works quite well as a MM stage.
True, but this IS a DIY forum, and the poster wants to build something.
jeff
jeff
A) No it isn't as I recall the write up I read, unless you modify it.
B) Pointless building something that will be no better than what you have.
I'm all for informed DIY, but not DIY for DIY sake when it will be no better.
rgds, sreten.
Good luck,
Nico
I have made a balanced in split passive Riaa MC pre with INA LT 1028 imput stage and
servos it has been working of Lead acid cels for the last 3 years.
I had the problems of the cels not charging up at same rate so I kept them in series and used a 150 ma Buffer to make the virtual ground.
There is better than Lead cells out there but can't say no more at present.
I like Rod Eliot site a lot and he is (my personal experience) alwayse willing to help well worth building same of his stuff.
I have been folowing the MPP tread I am a bit out of my depth there but again lot to learn and that is a forum I keep looking at
For easy passive Riaa values have a look at KABUSA web site.
Altrought I enjoied doing the maths to 4 decimal place a couple of times
I am revorking on my MC phono stage and going to get rid of one gain stage by conbining the the split passive in to a one shoot Riaa.
Eventualy I know I will go to a discrete but that is out of my capabilityes at the moment
Still loads of fun to be had it all depends on what you want and why you do this.
Build the Pearl? I would and will eventualy.
IF you wnat to start a jurney buiding things and the jurney is the to became the important part of it just get started
If you are not interested in the jurney itself to get low noise not even a INA LT1028 imput stage will be good enoug bateries or not
There is a good article by Jochim Gherard on linerar audio Down the Rabit hole that is well worth the price of the wholle mag.
The phono stages and the fact that this amp was from the era that this was the most important input is exactly why I bought my c4. I am extremely happy with it and the noise I mentioned before is far below the noise floor of any record. I think where I went wrong is I always read people talking about how silent their phono stage is even when they turn it up, and took that too literally. I assumed that if there was such a thing as a completely silent phono stage it would be easiest to do with a battery powered and separate phono pre. By the sounds of things, I was wrong, and this noise is a function of the gain required in a phono stage. Am I right?
Regardless, as vinylkid guessed, I do want to build something, but I would really like it to be at least comparable to what i have. From what Calvin said it looks like my best bet is the duplex. Are there other DIY phono pres that I have missed that you would recommend?
I have a inDiscreet that I built in 2004 which I am very pleased.
jauu
Calvin
I also had my doubts over the design before I built my inDiscreet pre pre, but it is quite different between theory and reality, inDiscreet must be one of the most underrated DIY phono pre out there.
At a meeting in the audio group as I am a member of we listened to a variety of phono pre amps both DIY and manufactured the only thing we had that goal was that it would be nice to lisining to. let the foot tapp, everything else was of secondary importance.
After a hole day of listening was 15 members agreed that the two phono pre which was most pleasant to listen to was Linn Linto and inDiscreet pre, it was a matter of taste which you prefer.
The other phono pre was
Gillis battery bc550
SRPP tube phono
Burmester
ASR basic V.?
Lyra (locally made​​)
Rotel
Anthem
Pearl
/Anders
Administrator
Joined 2004
You ought to also consider the Salas njfet phono stage right here in this forum. http://www.diyaudio.com/forums/analogue-source/129126-simplistic-njfet-riaa.html
While I am an all tubes sort of guy this design is highly respected, and worth a look.. Check out the GB situation for parts and pcb. May be a little more work up front for what will be a great phono stage.
I spent a couple of days working on it and it is early but so far I am realy impressed by it.
EASY to Sink your teeth in to and briliant to understand what is going on
