Old 15th September 2011, 07:55 PM   #1
Default Nad 533 - How to change a cartridge?
I have a Nad 533 turntable, and I want to replace the Goldring cartridge. However, I can't figure out how to remove the cartridge. Can anyone advise me? Thanks.
Old 15th September 2011, 08:30 PM   #2
533 Turntable - NAD Electronics
Hi.
Manual is at the above link, but its a standard Rega arm and mounting /
removing the cartridge is bog standard fare, checkout vinylengine.com .
You remove it by the bolts holding it in place, a new cartridge needs
bolting in position and correctly aligning see the above link again.
You of course need to remove and connect the 4 cartridge connectors.
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 16th September 2011, 05:46 PM   #3
Hi, Thanks but my question is even more simple than that; how do I remove the tiny bolts holding the cartridge in place? I've tried tweezers, small pliers... they're not moving. Is there a trick to it? Thanks.
Old 17th September 2011, 01:01 AM   #4
I severely recommend getting someone who knows what they are doing to help you.
Being defeated by small nuts and bolts is not a good sign. No idea where you plan
to get your replacement cartridge from, perhaps get them to fit it.
rgds, sreten.
Cone flap after cartridge change nathanjh13 Full Range 0 28th December 2010 01:44 PM
NAD 510 opamp change Citizen Kane Digital Source 1 3rd March 2009 07:31 AM
Stromberg Carlson ASR 533 kc5scs Everything Else 0 22nd January 2008 02:58 AM
NAD 9000 Cartridge snoopyma Analogue Source 0 2nd September 2005 08:52 AM
What is a Hickok 533 worth? G Tubes / Valves 3 9th December 2003 05:30 AM
Page generated in 0.07416 seconds (71.45% PHP - 28.55% MySQL) with 10 queries
