| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
Hey guys, i just saw this easy way to clean old dirty records with titebond....
#2 |
It works, but you will ruin a few records in the process...I'm sticking with soap /wash/rinse/vacuum ...
#3 |
okay that mask peeling off gets me idea of using a Face peel mask , the cosmetic thingies..
apply leave to dry, in 15mins remove, comes as a layer, I guess wont damage the material as its meant to be used on face, would be softer on this material.. |
#4 |
its also meant to moisturize, "feed" and do whoknowswhat to the face, so it would probably leave greasy residue...
#5 |
There were some articles in Audio Amateur by Reg Williamson about something like this (probably ca. 1978-1979?). He dissolved PVA and a little wetting agent in a water/alcohol mix to form the "facial peel."
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#6 |
#7 |
#8 | |
thanks for linking the thread, I have more than enough unlistenably dirty vinyls to give it a go... |
#9 | |
It really is the 'go-to' thread for a sensible discussion,investigation and comparison of methods and results that one can find on the 'net about this subject. |
| New vinyl cleaning method invented | Shaun | Analogue Source | 25 | 16th May 2010 03:47 AM |
| Best method for cleaning | burningbushhifi | Solid State | 4 | 16th July 2009 09:30 PM |
| My LP cleaning method | oshifis | Analogue Source | 23 | 12th March 2009 05:31 PM |
| Getting into LP... for real! | DragonMaster | Analogue Source | 56 | 26th September 2006 10:18 PM |
| Page generated in 0.08349 seconds (84.15% PHP - 15.85% MySQL) with 11 queries |
