| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
I've made a delay from two desktop cassette recorders. It works, and the delay is ~3 seconds. Today I'm going to attempt to place another playback head right after the recording head.
I'm wondering about building a simple circuit just for tape head playback. I'm physics-minded in general, but know little about electronics. I found this thread: cassette (tape) player circuit But don't follow it all... And supposing I wanted to make an extra stage of gain for bass, does it go like opamp ->RLC bandpass -> opamp? Thanks! ImageShack® - Online Photo and Video Hosting |
#2 |
Modifying parts are usually wraped around opamp in feedback path. See opamp tries to make negative input look just like positive. So if you reduce low frequency in feedback path the output will show more (bass boost).
As to your tape echo project, you might try finding a three head machine, as theiy're getting cheaper all the time. But if you're set on adding head and electronics yourself you might look at a TA7626p IC that was made by toshiba. Nearly all the record/playback circuits in one chip. If you can't find that look at old National Semi Ap notes for tapehead playback circuits. Doc
Ne timeas a facie mulierum ea ignorare Last edited by thaumaturge; 10th September 2011 at 02:07 AM. |
#4 |
Cheaper still is to go by a thrift store and pick up a used portable cassette player and use the guts out of it. Why reinvent the wheel... unless just for fun?
Doc
Ne timeas a facie mulierum ea ignorare |
#5 |
cool project
i dont know if youre familiar with the roland re-201, but if you'd like i could try and find the service manual (including the schematic) for you. i know ive seen it recently, and it might be a good resource |
| Repairing a tape echo with tubes (Dynacord Echocord Super 62a) | bigramp | Tubes / Valves | 89 | 7th May 2011 10:05 PM |
| converting a Maestro tape Echo to use a wall wart | helloitabot | Analogue Source | 2 | 1st December 2009 02:30 PM |
| tape echo search | infobot | Instruments and Amps | 7 | 12th September 2007 05:03 AM |
| Analog tape echo | Limhes | Analogue Source | 3 | 24th January 2007 07:45 AM |
| cassette tape echo / delay | thegunshyboy | Instruments and Amps | 10 | 23rd November 2006 11:36 PM |
| Page generated in 0.07553 seconds (84.07% PHP - 15.93% MySQL) with 10 queries |
