| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
About
Vinyl Flat Home I discover by chance an equipment to make maintenance and service by old vinyl records, especially if they are in a bent and warped condition. Are there already experiences ?? Thank you for your comments. |
#2 |
It's been the subject of avid discussion in our local audiophile club, but as yet no one I know has bought one. I can't see why it wouldn't work assuming time and sufficient rigidity.
I may ask for one for Christmas..
www.kta-hifi.net |
#3 |
seems like a couple flat plates and some bricks would do the same thing. Use something slightly resilient between record and plate. Start with a little weight and experiment?
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#4 | |
www.kta-hifi.net |
#5 | |
I bet a little gentle heat would also do wonders. heat the plates to ~140F, put a towel or two over them to insulate before loading on the books...
#7 |
You'd have to rig up some sort of rheostat to reduce the temp, but if it is large enough and has removable plates, I bet it would work better than you imagine
#8 |
I knew a gent who actually had one; from what I remember about the discussions with him, he recommends thoroughly cleaning the records before flattening as otherwise dust would be pressed into the records.
I think his experience was essentially that for slightly warped records it was working fine, for more extreme cases multiple tries were needed. However, looking at the link, his machine was a much more sophisticated unit. Hannes
fresh matched IRFP240/IRFP9240 fets || AlephJ/JX-kitsF5 transistor kits || Burning Amp BA-1/2/3 transistor kits |
#9 | |
Most of the books I have are not nearly heavy enough from experience.. I find it takes something in excess of 50lbs evenly applied across the entire record surface to do any good at all.
www.kta-hifi.net |
#10 | |
| About using a sound card to record vinyl | gaetan8888 | Digital Source | 16 | 7th May 2010 06:51 PM |
| Vinyl Record Cutting Dynamic Range Compression | oldheathkitphil | Analogue Source | 25 | 1st May 2008 06:52 AM |
| How to Pirate a Vinyl Record | Nordic | Analogue Source | 4 | 26th May 2006 01:23 AM |
| Vinyl Killer -- Battery Operated Record Playing Sound Van | Chris | Everything Else | 1 | 9th November 2005 03:44 PM |
| TEAC x-2000r record mode stuck. Record light flashes but won't play. Any ideas? | mistered05 | Analogue Source | 1 | 30th June 2005 12:51 PM |
| Page generated in 0.09715 seconds (83.14% PHP - 16.86% MySQL) with 10 queries |
