Old 29th August 2003, 02:53 PM   #1
Default Transformer for Thorens TD-166 MKII
I was given a Thorens TD-166 MKII and the transformer is missing. Does anyone have a scource for obtaining this unit?
Thanks in advance for any help that you can give.
Old 29th August 2003, 03:29 PM   #2
DRC is offline DRC  United Kingdom
DRC's Avatar
Default Don't know but ...
I have no idea where you can buy one but if you would like I can measure the one on my TD166 and give you the details for a substitution. Any good ?
From memory it's 9v ac, but I could be wrong.
Dave
Old 29th August 2003, 04:00 PM   #3
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
There's no trafo at all in my TD166 (And it plays)
Do I miss something?
/Hugo
Old 29th August 2003, 04:14 PM   #4
DRC's Avatar
Hugo,
My TD166/Mk2 has an 'inline' transformer on the power lead with a 3.5mm power connector (like a walkman) at the TT end. This is a UK spec TT for 240V/50Hz operation.
Dave
Old 29th August 2003, 04:20 PM   #5
The unit I am looking for is USA Spec for 110v, part# Z4150077. Dave if you could get me the voltage on the output side it would certainly help.
Pete
Old 30th August 2003, 06:15 PM   #6
DRC's Avatar
Thumbs up INFO
Pete,
My transformer reads 18v AC RMS unloaded.
I didn't measure the load current / voltage.
(no spare connector)
I would guess from the size (approx 45mm cube
including trafo, plastic box &cable entry/exit) no
more that 10W of output - probably a lot less once the motor is up to speed. Hope that helps ...
Dave
My Thorens TD166 MkII Snowdog Analogue Source 9 19th October 2007 12:00 PM
Thorens TD126 MKII lpd Swap Meet 0 8th September 2007 01:02 AM
Thorens TD-125 MKII Parts needlenose Analogue Source 9 12th March 2005 10:08 PM
W:Thorens 150 MkII pickupshell Zombie Swap Meet 0 1st September 2003 05:58 PM
Thorens TD 124 MKII question louis Analogue Source 3 2nd July 2003 03:27 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
