| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
Is it necessary to switch the grounds on my input selector? Or should I just wire all the grounds to the same grounding post and only switch the 'hot' lines with a 2 pole switch.
Basically what I'm asking is: 2pole or 4pole (both 6 position) switch? 2pole is vastly cheaper, which is why it's attractive. |
#2 |
There is also 3pole 4 position. No sure is more costly ? When you look inside there is 12 out terminal around and 1 to 4 terminal in center.
Praudio |
#3 |
3poles means i could switch grounds on each input if I wire them together, not sure if that'd be any different than a 2 pole. 4pos isn't enough.
#4 |
I prefer to use input ground switching because it helps to minimize the possibility of ground loops.
Mike |
#5 |
Here what I use:CK Rotary Switches | Lock Switch Manufacturers & Distributors | CK Lock Switch Module
See data for full details.
Praudio |
#6 |
I found these:
Digi-Key Item Number - C1D0406S-VA $36.75 Digi-Key - C1D0406S-VA-ND (Manufacturer - C1D0406S-VA) Surplus Sales of Nebraska Item number - (SWR) 1J54A5/6 $25.00 Sealed Rotary Switches - Page 2 (About 2/3 down the page) Mike |
#7 | |
I would use ground switching.
/IR Quote:
#8 | |
You can get quite nasty little bites when unplugging the inputs, or the interconnect to an earthed amplifier. Alex |
| Input Selector Switch | chrismercurio | Parts | 5 | 30th September 2010 04:54 AM |
| Where to buy a 6-pos Input Selector Switch? | Loren42 | Parts | 2 | 7th June 2010 09:52 AM |
| Phono input selector switch | Woodsong Audio | Analogue Source | 21 | 6th March 2010 04:19 PM |
| toggle switch for input selector | audio_moksha | Tubes / Valves | 25 | 14th November 2008 07:29 PM |
| Noise when using input selector switch | Nuuk | Solid State | 12 | 5th July 2006 04:11 PM |
| Page generated in 0.09119 seconds (75.12% PHP - 24.88% MySQL) with 10 queries |
