Entry Level Turntables: Any Suggestions?
Old 24th August 2011, 12:53 AM   #21
perceptionchanges is offline perceptionchanges  Canada
Originally Posted by kevinahcc20 View Post
Technics...SL1200 if you can swing it or lesser SL model. They are both good sounding with a well matched cartridge (Denon DL103R) and very durable!
+1
Old 24th August 2011, 12:55 AM   #22
rongon is offline rongon  United States
rongon's Avatar
Technics Model SL-1400MK2 - $150
If that TT is very clean and works 100%, then that's a very good price. How can you go wrong with that?
The SL-1400MK2 was basically a semi-auto SL-1200MK2 with a bit lighter construction and digital LED readout of rotation speed. It was simplified electronically from the 1200, with some IC's made for Matsushita instead of discrete transistors and lots of wiring (at least according to Technics SL-1500MK2, SL-1400MK2 & SL-1300MK2 on TVK).
KAB Electro Acoustics sells some upgrades and tweaks for the SL-1200MK2 that should also work for similar Technics tables. I put my 1200 on a "stand" made of a low end table with a slab of sandstone on top of it, with four Audioquest sorbothane feet I had lying around between the table top and the sandstone slab, and then replaced the 1200's stock feet with KAB's Sonic Domes ($30). I get no disruptions from footfalls or sound from the speakers, even on my room's not-so-solid wood floor.
I am definitely not stating that the 1200 is a "great" turntable. I don't think it's worth much more than $250 used, really. Its price is inflated by its DJ's "Wheel of Steel" status. But at $450 new, it was the best around, and I like the direct-drive sound (can't stop the beat!). It's also a proven durable design -- obviously, because so many of them have stood up to the abuse of DJ work.
I'd say that if you could find a Rega or a good Thorens TD-160 for $250 or so, then that would be great, especially if you prefer belt drives. But that 1400 for $150? And it's local? That's a deal if it's in good condition with no problems.
EDIT TO ADD: Beware Ebay. I talked a friend of mine into looking for and buying an SL-1300 for cheap. Of course he found that it won't stay on speed, even after cleaning all the pots and replacing PSU capacitors. I got a really nice looking Sony PS-X5, but it of course has the classic problem where the tonearm won't go in more than just past the beginning of the record before picking up and returning to the tonearm rest, and the motor shuts off (automatic auto-shutdown). On the other hand, I found a guy on craigslist who had an SL1200 that had been thoroughly abused, with a destroyed tonearm and plaster dust all over. I cleaned out the dust from under the platter and spun it up, and of course it locked right onto speed. I should have offered him $75 and taken it. I could have put some arm or another on later. The moral of the story is that you can't test a turntable on Ebay, but you can test it if it's local. My $0.02 is "Buy Local."
Old 24th August 2011, 01:11 AM   #23
a.wayne is offline a.wayne  United States
Sin Bin
Originally Posted by bear View Post
The original AR has the worst most awful arm anyone could make... my 2 cents. Ick.
I'll take the SL-1200 and put some home made isolation under it and do it for very little $$.
Like a box of sand?
The suspension on the AR was just springs, like the Linn for that matter... cheese.
Otoh, you can upgrade and mod it, but then it's not an AR, just an AR chassis and a lot of work...
There are better TTs out there... including some other Japanese brands...
If it's a starter system, I'd say "If it looks good, it is good"? You can usually tell build quality by looking... if it stays on speed, then it's likely good enough to get going.
Just my opinion(s). Ymmv...
_-_-
Just springs Huh ..................
Old 24th August 2011, 03:14 PM   #24
bear is offline bear
bear's Avatar
yes, just springs. say what?
(undamped springs, may I add that?)
_-_-
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 24th August 2011, 03:55 PM   #25
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
sounds like you are on to a new thread called how to build your own high end turntable
but sure thing, a turntable is a modders paradise, and nightmare
I would put more weight on a good riia/phono amp
it has always been a weak point
maybe its easier today
I don't know
Old 24th August 2011, 04:07 PM   #26
xmas111 is offline xmas111  United States
If you decide to go with the AR turntable(I don't think you'll be disappointed).
I did a basic rebuild on a AR XA a couple of years ago and was very happy with the results.
I put together a quick web page on the rebuilding process so if your interested in getting a AR XA and fixing it up a bit it might help you out a bit.
You can see the link in my signature if your interested.
Good luck with what ever you decide on. Spinning vinyl is the way to go.
John
Fun Stuff:AR XA Turntable Restoration
Old 24th August 2011, 09:58 PM   #27
sakellogg is offline sakellogg  United States
sakellogg's Avatar
John
i second this all.
you can put some time and effort into this table and leave it stock and it will sound great, if its not shot from the start.
as time, knowlage and money permits you have a nice foundation to build a giant killer.
what im saying is this......
if you decide on a arxa, you will have a (imo) mid level table stock, that is simple, easy to learn on and has the potental to grow with you for years.
and by grow i mean competing, perhaps besting tables in 1k$ range as mods are done.
if i might be so bold as to sujest...asking member: bamorrin
his knowlage on this table is somthing i relied on heavly durring my ar adventure.
there are things that you can do very cheaply (sub 100$) to make even a stock one sing and marc has forgot more about these than i will ever know.
Old 24th August 2011, 10:01 PM   #28
Sin Bin
The AR table can be brought to mad performance for a lot less cash than many would think and that sprung suspension works Bear , it will best a SL1200 every day of the week ..
Of course due to age it will have to gone thru and it doesn't have to be an AX , the later ones are well worth the effort..
Old 26th August 2011, 08:55 PM   #29
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
This table is pushing you budget but seems to have potential.
Oracle Alexandria in Detroit Mi-$250
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 27th August 2011, 01:19 AM   #30
CognitiveDiscord is offline CognitiveDiscord  United States
That Oracle sounds awesome, but it looks like it's in pretty bad shape... I've been watching a lot of auctions recently, and it's beginning to look like I haven't brought enough money to the table to make an effective jump into the vinly scene. I'm a patient man, though.
Entry Level Turntables: Any Suggestions?Hide this!Advertise here!
Entry level tube amp augerpro Tubes / Valves 36 9th October 2011 08:01 AM
Entry Level Turntable Telemin Analogue Source 30 10th September 2009 10:06 PM
Looking for entry level oscilloscopes dreamspy Parts 2 2nd May 2009 06:04 AM
entry level velodyne RockysDad Subwoofers 3 18th December 2005 06:04 AM
Entry-level Aleph advice? dantwomey Pass Labs 20 28th October 2002 04:13 PM
Copyright ©1999-2017 diyAudio
