Old 21st August 2011, 04:15 AM   #1
ashaw is offline ashaw  Australia
Default Oscillioscope pre amp.
I do not know where to post this. However as the problems I will face are similar to those faced with MC preamps, I thought I would post here.
I want to design a oscillioscope pre amp this will need to have the following specifications:
A selectable gain of 10,100,1000.
A bandwidth of 1MHz with a gain of 100.
Low THD.
Tolerant of 20V across the input.
An input impedance of 1MΩ||20pf.
Noise as good as any phono preamp.
Differential inputs would be useful but not crucial.
I was thinking of using a push pull Jfet amplifier. Powered by
Batteries however I would like some advice.
Alexis.
Old 21st August 2011, 04:48 AM   #2
thaumaturge's Avatar
Hey Alexis, why not learn from the best? Download a couple of Tek scope plug in schizmos from the boat anchor archive and see how they did it. However one common feature I recall from direct experience was nearly all of those I worked on used top quality mylar or polypropylene feed through caps for AC coupling. A quick glance of a 3A74 plug in sitting by my feet shows a 0.1uF on each of the four channels. I recall 465's had similar. Another high end plug in would be a Tek 7A26.
For op amps you might look at TI OPA1632 full differential and analog devices AD605 variable gain op amps.
Doc
Ne timeas a facie mulierum ea ignorare
Old 21st August 2011, 05:17 AM   #3
The problem is that the sensitivity of those amps is too low for my purposes. I want to use this preamp to reach 10nV per division sensitivity.
Old 21st August 2011, 05:48 AM   #4
Sorry that last line was a typo. I meant to say 10μV per division.
Old 21st August 2011, 06:02 AM   #5
To pull that off you'll likely have to go with a chopper stabilized auto-zero op amp. See Analog Devices: Analog Dialogue: Demystifying Auto-Zero Amplifiers-Part 1 and http://www.analog.com/static/importe...als/MT-055.pdf for more info. These unfortunately typically suffer from limited bandwidth (~200khz) but there may now be much faster models/variations/subs available. You might take a look at a Tek 7a22 diff plug in as a ref.
Doc
Old 21st August 2011, 07:32 AM   #6
blakkshepeaudio's Avatar
Old 21st August 2011, 08:52 AM   #7
Hello there,
Take a look at the Tektronix 7A22 - differential input, 10μV per division, 12V pk-pk measurement, DC-offsettable to 55V, safe to 200V.
Hope this helps.
Angus
Old 21st August 2011, 01:43 PM   #8
can this be used with a modern scope?
Old 21st August 2011, 02:07 PM   #9
luvdunhill's Avatar
http://tangentsoft.net/elec/lnmp/
Old 21st August 2011, 02:11 PM   #10
jackinnj's Avatar
The 7xxx line of scopes from Tek are still regarded as the "ne plus ultra" of analog scopes, and the manuals for the plug-ins are pretty generally available. There is a really active Yahoo group as well.
It might be less expensive for you to purchase a 7A22N or 5A22N and have it shipped to NZ.
One thing you want with a scope amplifier of this sensitivity is the ability to select bandwidth, and as mentioned previously, the ability to null the DC component.
Tektronix also makes a low noise differential amplifier plug-in, the ADA400A. It's still in production -- 5uV sensitivity to 1MHz with selectable bandwidth. Some of the Tekscopes will power this preamp directly.
MC pre pre amp for shelter 501 MK11 cjcc67 Analogue Source 19 24th May 2010 07:17 PM
Blown amp pre-amp in or HU pre-amp out? scraph Car Audio 5 23rd January 2009 12:58 AM
Velleman HPS-10 Oscillioscope newbie1 Parts 0 6th January 2004 02:44 AM
Passive pre amp vs powered pre amp fatmarley Solid State 21 21st November 2003 02:01 PM
Page generated in 0.10148 seconds (77.36% PHP - 22.64% MySQL) with 11 queries
