Old 19th June 2012, 09:06 PM   #41
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
The 50 Ohm resistors i crossed have to be 10 Ohm. So 25mV is developing over the 10 Ohms. That also sets the idle in the output stage.
The emitter loads of the input BJTs are bootstrapped with a copy of the output signal.
That way they see a high impedance. This is simpler then the current mirror you see here usually and works very well too. The collectors are connected to the output transistors and not to the opposite supply as usual.
Old 6th July 2012, 09:11 AM   #42
WT is offline WT
Hi Joachim,
I would like to build Your phono design as in post #1. I can not find BF246A. Can I use other type of Jfet?
Old 6th July 2012, 02:48 PM   #43
Yes, you can use other N-Channel J-Fets as long as Idss is higher then the current you want to send into the circuit. Which one can you get ?
J310 for example ? The higher the Idss is to begin with the more you can degenerate the Fet and that usually increases output impedance, thus improving PSRR.
Old 6th July 2012, 04:43 PM   #44
You can also use the J309 and there are other BFs.
Old 9th July 2012, 08:14 AM   #45
WT is offline WT
Thank you so much for your reply.
Can I use them j111 instead.
Old 9th July 2012, 10:04 AM   #46
Yes, J111 should work too. Idss is around 20mA, cutoff voltage around -3 to -10V.
You have to watch if there remains enough voltage over the 1kOhm pot.
Old 10th July 2012, 09:36 AM   #47
WT is offline WT
Thanks again. I will try J111 and J112 then. Hope it work.
Old 10th July 2012, 12:24 PM   #48
Yes, it will. I would set the current from 3.5 to 6mA.
Both, positive and negative side, the same.
Old 19th July 2012, 10:51 PM   #49
The work on the SBP ( Solar Batterie Poweramp ) made some progress.
I simplified the output stage to a CFA ( Szikley ) and added the possibility of current drive.
3 kinds of drive are now possible :
Voltage Drive
Current Drive
Open Loop ( output stage not in the feedback loop like Stasis )
Circuit diagram will follow when the prototype works as advertised.
Old 20th July 2012, 12:51 AM   #50
Thats it for today...
My first discrete amp danfo098 Solid State 60 30th July 2009 06:40 AM
Best discrete regulator ? ANADIGIT Solid State 1 1st December 2008 03:55 PM
discrete DAC Bernhard Digital Source 6 26th September 2008 01:24 PM
My discrete opamp udip Solid State 51 8th August 2006 08:33 AM
which discrete preamp ? sopapo Solid State 12 13th January 2006 09:11 PM
Copyright ©1999-2017 diyAudio
