Old 9th November 2011, 02:52 PM   #21
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Do you think about something like that : PLK1182-ND ( Digikey ).
I made good experiences with common mode chokes too on the DC side.
Looking at post 16 again i think it is better to raise R4, R15 to 300 Ohm. That lessens the noise contribution of the second stage, drives the second stage more into class A and gives a slight open loop gain increase.
Old 9th November 2011, 07:08 PM   #22
kamis is offline kamis  Serbia
Yes, but horizontal types are better when you have enaugh space to mount them-less radiated noise.It is very strange why CM chokes are so rare as filtering component in linear P.S.
Old 9th November 2011, 07:54 PM   #23
I think so too.
Old 9th November 2011, 08:03 PM   #24
Could you give me a hint what choke you prefer ?
Here is an interesting parer about noise suppression :
http://industrial.panasonic.com/ww/i...l/TT0001_e.pdf
Old 11th November 2011, 02:55 PM   #25
I am using CM chokes similar to Digikey distributed Panasonic series 4oo types.
They are 0.8A 68mH. If they are good enaugh for 300000$ Blowtorch or 4000$ Parasound Jc-2.......
Old 17th November 2011, 01:55 AM   #26
I found a simplified schematic of the Blowtorch PSU. JC seems to use the common mode chokes just like me.
Old 17th November 2011, 07:19 PM   #27
It is not Blowtorch power supply, it has never been published. Presented circuit was posted a long time ago by a French guy who was trying hard to guess Mr. Curl designs. All we have is detailed Mr. Curl description from which we see that he uses two rec. bridge approach , CM choke in the same way as you did in your PS. Unlike Frenchman, he uses adj. regulators in textbook manner, and furher down series resistor and simple open-loop shunt regulator of unknown topology, not IC referenced one.
Near the circuit, there are cap. multipliers , he said with 1A Harris Mosfets.
Old 18th November 2011, 10:45 PM   #28
Thanks for this information.
Old 11th December 2011, 12:27 AM   #29
Holger, i know know what you meant. You want to use the common mode choke BEFORE the main transformer. That is of cause also possible and no bad idea. We have a more conventional line filter then.
File Type: jpg Circuit Example common mode choke ac.jpg (56.5 KB, 967 views)
Old 11th December 2011, 12:30 AM   #30
Sorry, wrong picture. This shows the common mode choke before the bridge. One possibility we already mentioned.
My first discrete amp danfo098 Solid State 60 30th July 2009 06:40 AM
Best discrete regulator ? ANADIGIT Solid State 1 1st December 2008 03:55 PM
discrete DAC Bernhard Digital Source 6 26th September 2008 01:24 PM
My discrete opamp udip Solid State 51 8th August 2006 08:33 AM
which discrete preamp ? sopapo Solid State 12 13th January 2006 09:11 PM
Copyright ©1999-2017 diyAudio
