Old 4th November 2013, 07:55 PM   #161
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
I am a little bit exhausted from the Krefeld show and will leave for Vienna soon.
I try to find a slot tomorrow.
Old 5th November 2013, 08:58 AM   #162
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Please do not bother... it is not urgent.... I will keep developing the layout and will post a better one soon.
How was the show ?
RC
Old 5th November 2013, 10:17 AM   #163
OK, thanks.
Old 5th November 2013, 10:19 AM   #164
Here is the pin out of the BC327/337 :
http://www.fairchildsemi.com/ds/BC/BC337.pdf
Old 8th November 2013, 08:32 PM   #165
nhinstruments
RCruz's Avatar
Et voila
Here you have my latest layout.... Please disregard the previous ones that might have errors in the output stage connections.
I would just appreciate your comments on the placement of the parts and particularly on the GND layout and smoothing caps.
I will off course study the pinouts carefully before implementation.
Does this design ever work in class AB ?
RC
Old 13th November 2013, 06:04 AM   #166
I just came back from the Vienna Show. A 12 hour car ride by night.
At first glance i would do the PSU and ground traces quite a bit thicker.
Well, where does Class B stop and Class AB start ?
The only " hard " Class B HiFi Amp i know is the current dumper in the Quad 405 ( and siblings ). There is absolute no bias i think. Even the small bias i use in the Szikley output stage of the Nobrainer amp i consider as Class AB. Curiously when you read Self a Szikley has minimum distortion at very low bias. He shows that graphically as the waveform in transit from the NPP to PNP output transistor. When you " over bias " a Szikley, the distortion goes up. Unfortunately he does not show an FFT spectrum so it well can be that mostly second rises when you go from say 15mA to 125mA of my prototype. That can sound " warmer " or " better " although THD as such goes up.
Old 17th November 2013, 03:52 PM   #167
This one can be used if more power is required :
http://www.ti.com/lit/ds/sbos100a/sbos100a.pdf
Old 17th November 2013, 08:18 PM   #168
nhinstruments
RCruz's Avatar
Thank you
RC
Old 18th November 2013, 06:06 PM   #169
nhinstruments
RCruz's Avatar
Using a +-35V psu, how much power can this circuit deliver into a 4ohm load ?
RC
Old 18th November 2013, 06:11 PM   #170
FdW is offline FdW  Netherlands
FdW's Avatar
I * I * R
V * V / R
My first discrete amp danfo098 Solid State 60 30th July 2009 05:40 AM
Best discrete regulator ? ANADIGIT Solid State 1 1st December 2008 02:55 PM
discrete DAC Bernhard Digital Source 6 26th September 2008 12:24 PM
My discrete opamp udip Solid State 51 8th August 2006 07:33 AM
which discrete preamp ? sopapo Solid State 12 13th January 2006 08:11 PM
