| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
I found something called Luckydog Transimpedance Phono preamp.
Anyone ever heard of it? If so is it worth making? How would it compare to the relic from the 1970's? The relic is from the Barney oliver amplifier produced in around 1972 for HP employees. Last edited by Original Burnedfingers; 20th August 2011 at 06:30 PM. |
#2 |
The luckydog wouldn't work well for moving magnet cartridges that expect to be loaded by about 47k resistance, but may work OK for moving coil if circuit noise is low enough (but I doubt it). The other one might be alright, but proper ciruit layout would be critical.
Maybe something like this would be a good alternative: http://www.national.com/ds/LM/LM4562.pdf Mike |
#3 |
#4 |
mc or mm is the 1st question, after that "cheap" neds some parameters - are you only buying $0.30 op amps?
some would consider even a OPA627 design "cheap" at $20 ea - especially if you buy new parts for power, case, connectors and include any implicit labor rate for the ordering/build time |
#5 |
Parameters....MM not MC
Cheap down and dirty 5532's something that would better the $18 ebay china models build on perf board for trial |
#6 |
diyAudio Chief Moderator
In case of input op amp failure, the cart goes. I would add an output coupling cap since there is enough gain for the second op amp to multiply dc offset and there is no servo.
#7 |
I hate to admit this, but...
I had been tinkering with a rather complicated vacuum tube design sent to me by another forum member. It didn't work right and was rather microphonic. I lost my patience and built a little chip amp that goes inside the turntable and works too good. Just grab the data sheet from National Semiconductor and built it. It's on the front page of the data sheet and on this page too. I made an SMD version, but DIP's and even round metal cans are available. LME49720 - Dual High Performance, High Fidelity Audio Operational Amplifier
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#8 |
6BG6GA,
What cartridge are you using, and what are the manufacturers loading specs? Mike |
#9 |
Hi Tubelab,
Yep, that's the same thing I posted, only difference is that National renamed the old LM4562 to LME49720 for some reason. Great minds think alike. ![]() Mike |
#10 | |
| In search of power supply schematic for phono preamp | jduffy | Tubes / Valves | 16 | 9th April 2007 04:58 PM |
| Cheap and Easy Tube Phono Preamp | Kofi Annan | Tubes / Valves | 50 | 16th November 2004 12:37 AM |
| Page generated in 0.09989 seconds (76.73% PHP - 23.27% MySQL) with 11 queries |
