Old 15th August 2011, 04:07 PM   #1
Default Air compressor for tangential tonearm
Hi all,
My good friend Karel, a very talented handyman, is building a tangential tonearm on a cushion of air (which I hope a copy will be used on one of my turntables) somewhat in the style of this one:
http: / / www.trans-fi.com/terminatortonearm.htm
So it seems we have to use an air compressor or something like that. Area in which I know nothing. Should we use an air pump or a compressor for fish tank or something else? What features should we consider? And of course, how much does it cost? Apparently, it is desirable that the airflow of the unit is adjustable according to the arm with which it is used.
For audiophile use, it is clear that an appliance as quiet as possible is desirable.
Thanks in advance for your help.
Cristobal
Old 15th August 2011, 05:36 PM   #2
indianajo's Avatar
You adjust the airflow with a needle valve, like the ones from mcmaster.com (expensive) or electronicsurplus.com (cheap but will be gone someday). Gate valve are some use for fine adjustments, but ball valves don't have fine adjustment.
Fan based "compressors" should provide enough pressure, but if you use a diaphragm compressor or something with a piston, you will need a large enough tank to even out the pressure pulses. Squirrel cage blowers provide a little more pressure than an actual axial fan.
Be sure to use inlet and outlet filtration and an air dryer. You don't want dirt or moisture in this bearing. Self draining dryers are best unless you like conforming to rigid preventative maintenance. schedules. Installing one dryer, followed by 25' of tubing or a heat exchanger, followed by another dryer, gets you the driest air.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,SP2-XT's, T-300 HF Projs, Steinway console, Herald RA88a mixer, Wurlitzer 4500
Old 15th August 2011, 06:00 PM   #3
May I suggest using a tank say five gallon and fill it be for use . This will even out the flow and not have the noise and pulsing problems of pump. a regulator will be need but it is the quietest way to do it . given the small amount needed . Or use a 5 gallon bucket ( say one that drywall compound comes in ) set up like the web site with some poly fill in it to buffer the pulses of the pump. this will take time to fill up so start the pump before you want to listen but it will give you some buffer it you loose power .
I favor the high pressure tank with good regulator but that will be more expensive . Then emailing the web site and ask about pressure and flow amounts this should be in psi and cfm amounts if the tell you in metric there are conversion software on the web.
Old 15th August 2011, 07:42 PM   #4
Go to your local pet shops and get a good quality aquarium pump. Avoid the cheapest ones - aim for the middle ground. Using a big shop compressor will give you hiss problems at the arm, the aquarium pumps don't have this problem.
I'm using an "interpet av4" airvolution aquarium air pump, gives 2x 300 litres/hr at 0.23mbar. It's pretty quiet, but you will still need a buffer chamber like a 5l can.
Fran
Visit www.tirnahifi.org!!
Old 15th August 2011, 11:53 PM   #5
AVWERK is offline AVWERK  United States
You don,t say how much air pressure you need, but whatever you do you need to regulate just enough and no more air than needed.
You can use black PVC pipe say, 3" or 4" in dia. And make 1 or two in series at different lengths. One at 16" or one at 12" and the other series at 24". The idea is to smooth out pulses that come from whatever pump you use. Stuff one or both with Dacron pillow stuffing (synthetic material)
The dryer stuff will depend on whether you are using very high pressure (likely) to not needed with low pressure say, 3psi (unlikely) and the climate you live in.
David
Old 16th August 2011, 04:12 PM   #6
Sourdingue's Avatar
hello, I designed this air supply to my arm tangential diy ... if it can inspire you? a lot of air flow and very very quiet!
The link : DIY platine vinyle : Réalisations personnelles - DIY - Page 17
Air bearing tonearm Sourdingue Analogue Source 4 31st August 2010 05:00 PM
Silencing an air compressor wxn Everything Else 17 25th February 2010 05:47 AM
Help with Air Bearing Tonearm Binaural Analogue Source 5 22nd April 2009 12:43 AM
DIY air compressor. help needed peterr Everything Else 4 8th September 2005 01:10 PM
MG-1 AIR BEARING Tangential Arm audio-kraut Analogue Source 7 24th November 2004 07:55 PM
Page generated in 0.08657 seconds (74.42% PHP - 25.58% MySQL) with 11 queries
