| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
While waiting for my new TT (Pro-Ject RPM 1.3), I need some guidance whether to mod my existing phono-preamp (old B & O) for the Ortofon 2M (Red) cartridge or should I go ahead and diy the famous J-Fet phono-preamp?
#2 |
Keep the old and try with input capacitance...you might like it?
#3 |
#4 |
Also try 100K trimmer instead R3 fixed 56K so can get best input load for your MM cartridge.
#5 |
So far: (1)Will experiment with different values for C1, (2)Replace R3 with 100k multi-turn pot and (3)Insert 100pF capacitor across R1.
#6 |
Pay attention load input capacitance in parallel with R3 (try manufacturer suggestions something between 150-300pf if possible type silver mica), I suppose C1 it's to avoid input DC so if you don't use a MC pre-pre you can get off.
#7 |
Typo on my side, suppose to be 100pF across R3. Do you mean remove C1? (cartridge MM)
#8 |
If you will use only MM cart or you are sure that MC pre-pre don't have DC output, yes I remove C1
#9 |
I get it, will short out C1 after measuring if any dc exists.
#10 |
| Hafler 9270 Toroidal Xfo Mod - A Different Hafler Mod | Taterworks | Solid State | 1 | 26th May 2011 04:33 AM |
| I want to MOD - help? | auditude | Tubes / Valves | 3 | 2nd April 2008 08:38 PM |
| help to mod | leimaster | Class D | 5 | 10th December 2006 09:24 PM |
| Mitsubishi DD-8040: to mod or not to mod? | FastEddy | Digital Source | 0 | 4th November 2006 01:20 AM |
| Marantz CD75mkII to mod or not to mod that is the question. | El_Hefty | Digital Source | 6 | 31st August 2006 01:29 PM |
| Page generated in 0.09828 seconds (74.02% PHP - 25.98% MySQL) with 11 queries |
