| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
I just picked up about 300 old 45s and the following system: 1. Harman Kardon 330A (70s vintage?) 2. Fisher 302 turntable (Made in West Germany) 3. Large set of old speakers (no name brand visible except for a paper stapled on the back explaining the difference between ohms and comm screws for stereo sound) The turntable has an accessory that appears to be able to stack a number of 45s on it. I got home all stoked to get this thing going and I have had a lot of frustrations. 1. hooking up the original system, the sound cuts in and out endlessly and it seems that I need to fiddle with the old RCA-type connectors coming from the turntable to the HK unit. I have tightened the cord on the ground post on the back of the HK, but not much luck - everything sounds fine for a moment and then it either gets way worse or cuts out entirely. 2. I cannot get the turntable arm to go over to the record - it seems to want to and if I give it a little lift with my finger initially it goes over there, but only with help. 3. When the record/track is complete, the arm goes back to the resting post, but again, I need to help it on to the post. grrrrr..... Lastly, I hooked up a modern set of speakers, played the HK on FM only and the sound and everything seemed to work fine... Any advice, suggestions, or do you know where I could find some manuals for these things? I would like to keep as much of the old set together as possible. Most importantly, I want to get that turntable functioning to load multiple 45s if that is what it is supposed to do. cheers, Myron |
#2 |
Your 'Fisher' is a Perpetuum Ebner, probably 2040, their last product before Dual bought them in 1972. Manuals should be aailable at the vinylengine.
#3 | |
G² |
#4 |
Worked on a bunch of 330As back then. They had a tendency to have thermal power transistors that go open circuit when hot and recover (often) when cooled off. I used to replace the outputs with 2N6488s with great success.
G² |
| Soundstream Rubicon 302 | mike49504 | Car Audio | 20 | 6th June 2010 02:09 AM |
| NAD 302 Improvements | ben556473 | Solid State | 10 | 7th April 2007 12:14 PM |
| need help with cd-302 | dial | Digital Source | 2 | 24th October 2006 03:46 AM |
| NAD 302 schematics? | showdown | Solid State | 3 | 21st October 2005 03:33 AM |
| Page generated in 0.07948 seconds (74.43% PHP - 25.57% MySQL) with 10 queries |
