| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
hi, I'm looking for upgrading the wires in my tonearm (stock sl-1200).
Their are so many options and so expensive! First of all, rca plugs and interconnects going from my tonearm to my phono! 1-I mean should I really spend 60$ for set of plugs? The eichmann seems good value for 60$ Eichmann Bullet, Furutech, and WBT NextGen or 2- their is all-in-one options like those Nordost : Products : Tonearm Cables or Silver Series C4 Tonearm, or canare which offer the plugs and cable. Please note that I don't have 500$ to put on the nordost product, I want the cheaper, no non-sense priced cable Which option should I choose, please recommend me cheaper alternatives and your experience. I'm not looking for the ultimate sound with no money barrier, rather the best-bang for the buck option. Tonearm wiring: From van den hull to mouse wires and everything in between, what do you recommend for a good budget tonearm wiring. If it's worth it, I would go with vandenhull price, but I'm sure theirs cheaper options... Thank you Last edited by murphythecat8; 19th July 2011 at 07:11 PM. |
#2 |
Neutrik rca's at $5-6 / pair are excellent.
Cardas 4x33awg for tonearm,inside & outside.With this you can also make some nice headshell wires. |
#3 |
price-performance-wise I´d opt for a very flexible stranded HF-litz copper wire. I got mine as free sample (well, it took one call and one email to the manufacturer, who also offers silver HF-Litz), but You can get such wire for a few bucks on ebay too. I chose 10x0,05mm/AWG44, grade1, silk spun. I´ll twist the two wires of each stereo channel to reduce noise pickup and run each channel thorugh a drinking straw. As connectors to the pickup I´ll use female D-Sub crimping contacts FK20SL from FCT electronic, but You may slaughter any old female Sub-D for contacts. Symmetrical output connectors will be the Fisher S102 and WBT234 for RCA (simply because of having a couple of them lying around). A more classical XLR-style connector from Neutrik et al will do the job as well. I can honestly not recommend one of the mentioned boutique RCA-connectors, because the mechanical quality and the finish of those can be terribly -to ridicolously- low and I don´t see any justification for their exaggerated price tags. I keep the tonearm wire short, since its crossectional area is 0,02mm² small and as such its impedance is somewhere in the range of 0,8-1,0 Ohm/m. Playing low output MC cartridges a too high impedance will lead to increased signal loss. jauu Calvin Last edited by Calvin; 20th July 2011 at 10:44 AM. |
#4 |
Suitable tonearm cable you can buy for the (ridiculously low) price is from this guy:
transfiaudio items - Get great deals on items on eBay Stores! Unlike other tiny shielded wires, this one is easy to work with. Same source also offers cartridge clips. For cable you might use two VAN DAMME - 268026C starquad cables - one for each channel - just wire two white conductors together for signal and two blue together for ground. Or use smaller diameter Van Damme two-conductor+shield cable. Or you can cook any cable you prefer. For RCA connectors, there is safe and great choice - neutrik NF2C-B/2 connectors. Connect shield of the cable inside tt to GND post or lug - if it has one, or hardwire any insulated wire to shield and run it to the GND post of phono preamp. Do not connect shield of the cable to anything else. |
| rewiring the lenco tonearm - AAAAAgh | lorienblack | Analogue Source | 4 | 31st October 2009 01:52 PM |
| Need suggestions for my next TT - totally lost in the sea of TT models | Razorblade | Analogue Source | 10 | 22nd April 2009 12:28 AM |
| rewiring a Sony PUA-286 tonearm | eidling | Analogue Source | 1 | 8th October 2006 06:43 PM |
| Rewiring tonearm without hum? | tmblack | Analogue Source | 12 | 1st March 2005 03:36 AM |
| DIY tonearm for rebuild tt | Alexander | Analogue Source | 2 | 15th January 2004 08:50 AM |
| Page generated in 0.09296 seconds (77.99% PHP - 22.01% MySQL) with 10 queries |
