Old 19th June 2011, 09:37 PM   #1
YAKI is offline YAKI  Israel
Default Suggestion for plywood turntable finish
Hi
I am building my turntable base made of plywood. Top and bottom of the plate is glued with 6 mm aluminum. So, I need to finish about 60 mm all around the plate. Painting is problematic since plywood is not a uniformed material from that perspective - 50% of the wood is always vertical, hence, hard to finish.
I thought about veneer cover, but I have a 90 degrees corners and it won't bent that easily, I believe without breaking...
Any suggestions for me? The best would be painting or veneer, but I am not sure it will work out....
Old 19th June 2011, 10:01 PM   #2
nigelwright7557's Avatar
Fine sanding then wax or stain.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 19th June 2011, 10:19 PM   #3
What is stain? can't find the right translation... is it a material to apply on top?
Old 19th June 2011, 10:21 PM   #4
Its like varnish like they use on tables.
Old 19th June 2011, 10:27 PM   #5
sure, varnish is very nice, but it is very hard to do on the "sides" of a plywood... Unless I am doing something wrong there... Any help and suggestion will be highly appreciated
Old 19th June 2011, 10:29 PM   #6
Personally I wouldnt use plywood.
I would have bought a veneered finish wood chip or similar.
This would be a heavier base and more suitable for a plinth.
It also has veneered sides which helps.
Old 19th June 2011, 10:35 PM   #7
Use some car body filler on the open grain (David's isopon p45). Put it on with a paint scraper, pushing it well into the open grain. Sand back and repeat until you have a fine finish. Then undercoat, sand back, repeat. Eventually put on your finish coat......
I've done a few like that and it works well.
Fran.
Visit www.tirnahifi.org!!
Old 19th June 2011, 10:58 PM   #8
49 - for the 16th time
c2cthomas's Avatar
Take a look at this link Larry Eisinger's Home Repair Workshop - Popular Ways To Finish Plywood Edges
Methods are available via the 'net
"You can't always get what you want" K. Richards/M. Jagger *** "Next time I will know some things better" Zen Mod
Plywood or MDF? greg_mcquaid Subwoofers 30 10th July 2011 06:37 AM
Looking for a very transparent plywood finish...ideas? Glowbug Construction Tips 6 26th July 2010 03:42 AM
plywood joins PeteMcK Multi-Way 26 9th June 2009 10:22 PM
Pine-plywood Tachyon Full Range 13 22nd March 2005 12:27 PM
Page generated in 0.08738 seconds (75.41% PHP - 24.59% MySQL) with 10 queries
