| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
I'm new to DIY audio and wanted to build a phono stage since mine is broken. I can measure an amplified signal at my RCA output connections but when I plug it in to my amplifier (an old Marantz) the signal disappears and I can't measure anything and there is no sound. When i unplug the output RCA from the amplifier I again can measure a signal with my multimeter. Anyone has any idea why this is and how to fix it?
Thanks kasn |
#2 | |
G² |
#3 |
Its based on the Velleman kit K2573 (Velleman Inc.) and I know the outlet I try to plug the phonostage in to is working sense I use that outlet for my CD-player and that's working fine. Thanks for the quick reply.
#4 | |
Two recommendations: 1: add a small value resistor (22 to 100 ohms) in series with the outputs C6 and C10. This will reduce capacitive loading on the opamp and prevent oscillations. 2: use a regulated power supply as any variations on the AC line Voltage will add low frequency thumps in the output. If you run on a pair of 9 Volt batteries you won't need a regulator. G² |
| RIAA stage problem ... | jiiteepee | Analogue Source | 13 | 9th August 2010 02:31 PM |
| First DIY project, Charlize problem | atldiyr | Class D | 3 | 15th September 2008 07:42 PM |
| Krell PAM-5 schematics for riaa problem. | webercarbmann | Solid State | 0 | 4th June 2007 05:28 PM |
| My RIAA Phono Stage Project | sorenj07 | Tubes / Valves | 16 | 10th September 2006 09:18 PM |
| Page generated in 0.07584 seconds (75.38% PHP - 24.62% MySQL) with 10 queries |
