| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#81 | ||
Basically the requirement for plinth mass is in response to Newtons law that requires that every force has an equal and opposite reaction. In rotational terms, every torque has an equal and opposite reaction torque. Therefore a high torque direct drive like the SP10 mkII will tend to spin the plinth as motor torque is applied to the platter. The greater the plinth moment of inertia, the harder it is for the plinth to move even microscopically. Bear in mind the minute scale of the information the stylus is retrieving. I suppose there is a practical limit to the amount of inertia. The material stiffness is of consideration here because the plinth will have the frequency of its principal mode of vibration determined by the inertia and rotational stiffness (compliance). It would be desirable for this frequency to be away from frequencies of likely sources of extraneous excitation. In practice the choice of available plinth material limit the scope of choosing the principal mode frequency. Quote:
The SP10 mkII mold template includes the cut-outs for the turntable and armboard. This is my reasoning for the effectiveness of a layered construction: assuming a perfect DD motor system, and ignoring extraneous inputs, the plinth requirements are to resist torque reaction (mass) and to effectively damp whatever the inertia doesn’t soak up. Since in the idealized situation this rotational motion is in a horizontal plane, a horizontally layered plinth with suitable damping material between layers is very efficient at converting any motor induced horizontal torque motion of the plinth into heat by shearing of the horizontal damping layers. As an added benefit, such a ply structure has considerable transverse stiffness and therefore coupled with high mass, provides an excellent platform for mounting of a tonearm.
Bon "Moderation is a fatal thing. Nothing succeeds like excess." Oscar Wilde. |
#82 | |
I have a supreme on my SP-15 and it is absolutely stunning |
#83 |
There's an interesting thread on sp10 mkII bearing damage going on over at AudioKarma. Here's a link:
Bearing wear on an SP 10 mk II PICS - AudioKarma.org Home Audio Stereo Discussion Forums |
#84 |
I've stalled out on this project because of....well.....caution. The bearing housing bottom cap. The part that houses a thrust ball bearing. This I assume is a threaded piece that screws onto the upper housing casting.
Here's a photo: ![]() The red arrow points to the part I mean. Moderate unwinding force, using implements of destruction, will not budge the piece. Until I gather some more information on just what is involved in the attachment of this part to its mating part, I'm not going to proceed. These are the only parts I have. I can't afford to break any of it. I'm "guessing" that it is indeed a threaded part and that there may be some thread sealant/thread locker applied to the threads from the factory. If this is the case, I'll probably resort to something like a strap wrench after getting some penetrant oil into the threaded joint overnight. Or so I think. Anyone have any experience taking this part off? tia, -Steve |
#85 | |
The service manual doesn't show the motor housing in it's individual components. Figures. ![]() jeff |
#86 |
Location: Scottish Borders - Kelso; on the famous Tweed River!
The following url is interesting.
<http://www.vantageaudio.com/info/sp10acc.htm> I have tried to contact Vantage but they can be difficult to contact at times be it by email or telephone. They do brilliant restoration work and have sorted my SP10 with fully external electronics: although not yet completed, I saw the work just before completion and can say that I have not seen better. |
#87 | |
Good idea about the use of heat....and not too much of it. On the other side of that casting is a circular rack of coils with some sort of clear coating applied. We wouldn't want to melt that coating. ![]() -Steve |
#88 | |
I have yet to see any photos of the insides of the bearing cap I refer to. So I guess that means not too many of us diy'ers have actually refurbished their own SP10 bearings. Not good. These SP10 bearings are showing wear just like those of any other turntable after 35 years use. This will be a very important part of the project to get back into 100% condition. -Steve |
#89 | |
Here's where I'm at now: ![]() ![]() ![]() The photos do indicate a generous amount of thread sealant/locker. I used a heat gun to warm that up. The rest of the casting did not heat up. I installed the lower motor casing back into the chassis to increase the leverage when I applied a turning force using the strap wrench I just bought. Right Hand threads. The cap unscrewed smoothly but with quite a bit of drag from the goo stuck in the threads. I suppose it will be a good idea to re-assemble with same/similar sealant/locker. Victory -Steve |
#90 | |
Loctite Threadlocker Blue 242 from Loctite Adhesives jeff |
| Layered plinth for SP-10 | jlsem | Analogue Source | 74 | 13th April 2009 10:48 PM |
| Technics SP-10 speed problems | Stefanoo | Analogue Source | 3 | 17th August 2008 10:05 PM |
| Technics SP 10 Speed Problems | rollinr | Analogue Source | 26 | 21st June 2004 06:44 AM |
| SP 10 Service Manual | romero | Analogue Source | 1 | 13th April 2004 03:45 AM |
| Technics SP-10 MKII pitch control | peterb | Analogue Source | 6 | 28th March 2004 01:29 PM |
