Old 13th August 2003, 04:44 PM   #11
Netlist is offline Netlist  Belgium
Netlist's Avatar
Originally posted by Clark2000
Is that the same part that you were talking about? Is there a different one that is cheaper that I can use? I'm handy with a soldering iron and everything else, so if I can just order the new PCB that will accept the new 8-pin fader, I can replace the whole thing...
Thanks!
Of course the cheapest way is Eric's approach. Nothing to order anymore as you have the fader; fixed in half an hour.
If you like the original part, the one on the site you mentioned looks original to me and is plug and play.
The part I mentioned is a naked pcb with only the fader soldered in place. The LED, trimpot and wires have to come off from the old pcb. I usually bye it at +/- €15 (And sell it double of course )
Only problem for you will be ordering the EVBxxxxx part.
So, finally, if I were you, I would do as Eric suggests.
/Hugo
Old 13th August 2003, 04:45 PM   #12
karma is offline karma  Canada
karma's Avatar
did you try contact cleaner? it cleans and lubs. and on faders
i use a pair of needel nose pliers to tighten the steel cage around the fader to the pcb. should be like 4 or 6 little steel
fingers holding it together. thay loosen up over time. i got a few back from the dead doing this
but if it was used in a club there likelly used up
Old 13th August 2003, 04:49 PM   #13
Netlist's Avatar
I bet that fader is already full of that spray...
Shame on you Karma, advising spray on Pro-gear.
/Hugo
Old 13th August 2003, 05:10 PM   #14
mrfeedback's Avatar
To sucessfully service faders requires solvent/contact oil spray and high pressure compressed air to flush out any junk.
Often the carbon tracks are worn out and replacement may be the only option.
Eric.
I believe not to believe in any fixed belief system.
Old 13th August 2003, 05:11 PM   #15
/Hugo
Ok, I'm slightly comfortable doing this. Does anybody know which pins on the 8-pin pitch fader match up with the pins on the 6-pin fader?
Old 13th August 2003, 05:14 PM   #16
mrfeedback's Avatar
Default Laziness.... Huh...
If you have an ohm meter/multimeter you can work it out for yourself, or would you like one of us to come around and slap it into you !...
Eric.
Old 13th August 2003, 05:27 PM   #17
Netlist's Avatar
Default Re: Laziness.... Huh...
Don't forget the paper and pencil...
/Hugo
Old 13th August 2003, 06:22 PM   #18
Ok, so that was a bit lazy. Sorry, that's not really how I meant to come off.
I certainly appreciate all your help, and since at least one poster had mentioned doing this before, I thought somebody might have the answer on the tip of his tongue. I will try to figure it out on my own, but my "electronics skills" (in quotes because I don't really have any) don't go any farther than operating a soldering iron and solder sucker. I guess now is the time I'll learn some of this stuff!
Old 13th August 2003, 07:00 PM   #19
Netlist's Avatar
Well, if you don't have a meter it will be a bit harder.
Buying a cheap one could be a solution.
Otherwise, try to follow the printed circuit board layout,
and try to find out what wires should go where.
Make a drawing.
Presumably only 3 wires will go to the fader.
The others will go to the LED and the preset.
Good luck
/Hugo
technics sl d3 pitch control potmeter ret3k Parts 0 3rd September 2005 11:07 AM
Technics SP-10 MKII pitch control peterb Analogue Source 6 28th March 2004 02:29 PM
technics 1200 pitch correction megatron Analogue Source 4 23rd February 2004 08:11 AM
Technics 1200 MkII Pitch Problem silicuda Analogue Source 6 12th February 2004 10:34 PM
Technics 1210MK2 pitch control JodyG Analogue Source 4 12th February 2004 07:23 AM
Page generated in 0.10107 seconds (87.07% PHP - 12.93% MySQL) with 10 queries
