TD124 mk1 RB301 new plinth and service
Old 26th May 2011, 01:49 PM   #41
jlsem is offline jlsem  United States
jlsem's Avatar
Here is a photo of a Thorens 124 plinth I made for a friend of mine about five years ago. It is made from Panzerholz, which has a very hign damping capacity compared to solid wood and regular plywood.
John
Old 26th May 2011, 03:14 PM   #42
Helmuth is offline Helmuth  Netherlands
Helmuth's Avatar
John
You have done a great job there john.
( (( KUGELWELLE )) )
recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet
Old 26th May 2011, 05:49 PM   #43
kevinkr's Avatar
John
Looks like a very serious piece of kit!
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 26th May 2011, 09:11 PM   #44
jlsem's Avatar
Yes, it was built with another arm board at the rear to supplement the Thorens attachments. It's pretty solid. This plinth and another made for the Garrard 301 were the progenitors of a series of plinths I made for the SP-10 for Albert Porter.
http://cgim.audiogon.com/i/vs/s/f/1284840093.jpg
John
Old 28th May 2011, 12:20 AM   #45
kevinkr's Avatar
[QUOTE=Straight Tracker;2583937]
The picture of the capacitor seems to indicate that its value is 10 pF. It looks like the "p" is mangeled to appear like an "n". Correct me if I'm wrong.
Sincerely,
Ralf
As Helmuth has indicated it really is 10nF, I have seen three early 124s (one is a former parts unit I own) with the same cap he snapped a picture of, and it is clearly printed on the case. My newer 124/II also uses 10nF but from a different vendor. (Power switch is different oo)
Old 28th May 2011, 12:02 PM   #46
Helmuth's Avatar
Default Uncoupling
Hi
I a now listening to the TD-124 To tweak a bit. The paint job has to wait till the motor had a revision.
with the TT running and the coupling turned on we can lay the needle on the TT. The noise generated by vibration of the motor is now amplified. I can hear the noise is less when I lift the TT and hold it in my hands. So the solid rubber feet do not absorb enough.
Ok I have a good idea to solve this.
I have soft rubber 7mm where seats of supersport bikes made off I call it moosgummi.
Wiht the rubber between two triplex plates i can use the holesaw to drill a nice round pice of 40mm. In the bottem plate of 6mm i drill the same hole.
after that I can screw the assebly to gether again.the rubberfeet loose on a screw so it has suspension. Works really great to absorb the minimum vibration left in the plinth.
File Type: jpg Schermafbeelding 2011-05-28 om 13.54.53.jpg (42.3 KB, 263 views)
File Type: jpg Schermafbeelding 2011-05-28 om 13.54.33.jpg (27.1 KB, 263 views)
Old 28th May 2011, 12:28 PM   #47
Helmuth's Avatar
The first turns. The speed is very good constant I do not hear problems with that rumble is acceptable low my current TT is a Technics sl1700 witch has very low rumble figures and is more quit then the Thorens as long the needle isn't on the record.
The music reproduced by the Thorens with RB301 is more detailed and brighter bass is also good and tight. What is responsible for gain on brightness I think the silver tone arm wiring. And I think the heavy turntable help to be uninfluenced by the sound-pressure of the speakers and therefor doesn't mess up the low frequencies.
For now I am listening to the Grado red greatbudget cartridge it has a wide and big soundstage and and also good bass. The down side it has problems with the "S" compared to other cartridges it sss. When it is finished I will be running my most exspensive cartridge the goldring 1012. It has good detail and brightness witch with some records tents to sound to thin.
When it bothers me then I will switch back to the Shure M97xe really great cartridge very balanced. I have seen it measures very nice and I can hear it doesn't has the level of detail the Grado or Goldring does but it serves you with smooth tonal balance.
TD124 mk1 RB301 new plinth and service-schermafbeelding-2011-05-28-om-14-15-18-jpg
One day I want to upgrade to the DL103 But my kids play with my equipment and already broke two cartridges. And that would be to expensive with the dl103.
It would complete the color scheme of the TT and the gils will say the color of the TT looks very nice.
File Type: jpg Schermafbeelding 2011-05-28 om 14.15.18.jpg (45.0 KB, 340 views)
File Type: jpg Schermafbeelding 2011-05-28 om 14.14.55.jpg (48.0 KB, 33 views)
Old 28th May 2011, 01:06 PM   #48
Helmuth's Avatar
Close-up.
TD124 mk1 RB301 new plinth and service-schermafbeelding-2011-05-28-om-15-04-05-jpg
File Type: jpg Schermafbeelding 2011-05-28 om 15.04.05.jpg (33.2 KB, 314 views)
Old 28th May 2011, 03:30 PM   #49
user510 is offline user510
user510's Avatar
The switch capacitor is listed in the TD124 service manual as .01 uf.
Although the manual calls it a "condensor". At any rate, I've been using .01 uf value switch caps on my td124 projects and that value does prevent the speakers from popping as you swtich the unit on/off.
The conversion between uf and pf: .01 uf = 10 pf. So the 10pf value would be per spec in the service manual.
That's a nice looking setup.
-Steve
Old 28th May 2011, 03:44 PM   #50
Helmuth's Avatar
Hi steve you are making a fault of 1000 there 10pF =0,00001uF.
The capacitor has to be 10nF=01uF , in europe we call a capacitor a condensator and that in the manual will be a translation fault.
-Steve
Thanks steve you are very nice , it will get a paint job the wood transparent and the white parts going to be semi gloss-black. Then it will have a professional look to it I hope. First the motor must be upgraded and to prevent scratches I will wait till that is ready.
TD124 mk1 RB301 new plinth and serviceHide this!Advertise here!
Marantz CD17 KI MK1 Service manual wanted Fidelity Audio Digital Source 2 4th May 2013 11:11 PM
Service Manual for Rega Planet (mk1) squall2072 Digital Source 0 20th November 2005 07:11 AM
Thorens TD124 mk11 jonnypotter Swap Meet 3 8th September 2004 02:14 AM
Philips CD850 MK1 service manual anyone? tubenut Digital Source 2 26th August 2004 05:50 AM
Spectral DMC-20 MK1: Service Manual needed Blitz Solid State 0 2nd January 2003 09:21 AM
