TD124 mk1 RB301 new plinth and service
Old 23rd May 2011, 03:26 PM   #31
Helmuth is offline Helmuth  Netherlands
Helmuth's Avatar
Originally Posted by Telemann View Post
It's the pro-version of the Beogram arm of the time, called the ST/P, 12" arm, for radio stations and studios. Very pleased with the soundstage it delivers, but believe it will do an even better job when mounted on a slate plinth, isolated from the TD124, I'm thinking of doing that - and did have a Schick in mind before Kevin got his (so not copying, Kevin - emulating!)
I do not see the difference with the schick and your arm. How does schick solves forse that drives the needle inwards. Anti skating compensation
( (( KUGELWELLE )) )
recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet
Old 23rd May 2011, 03:32 PM   #32
Telemann is offline Telemann  Norway
Dudley goes into how Schick does that here:
Listening #87 | Stereophile.com
With my arm it's solved with the quite ingenious gimbal-system; perfect anti-skating with no lateral force applied.
Old 23rd May 2011, 04:36 PM   #33
kevinkr's Avatar
The Schick doesn't have anti-skating compensation, the high tracking force applied with the cartridges the arm was intended to be used with seem to greatly reduce or eliminate the need. (I also found to my considerable surprise that my ZU Denon DL-103 performed best without any anti-skating compensation even in my old 3009. Imaging and electrical channel to channel balance checked/evaluated..) I was a little puzzled by all of this, but having heard Schick arms on 4 different tables (including mine obviously) with various cartridges I have to say it definitely works, and better than anything else I have heard in the range I can afford. (Limited experience, and limited budget.)
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 23rd May 2011, 06:58 PM   #34
Helmuth's Avatar
Hi Kevin,
Ok the arm mass is that high it compensates that behaivour.
Here a picture of the massive bankirai inside. I will ad ventilation holes under the motor.
File Type: jpg Schermafbeelding 2011-05-23 om 20.48.40.jpg (46.1 KB, 264 views)
Old 23rd May 2011, 11:38 PM   #35
kevinkr's Avatar
Hi Kevin,
Not sure it is the arm mass, but more the actual tracking force used, usually the high tracking force cartridge also has low compliance and significant mass and is matched to a medium to high mass arm. My understanding is that the need for anti-skating goes away around 2gms. This is anecdotal - have not had much time to research the issue.
"Plinth" in English.. Looks very nice, assuming that you are definitely going with a 12" arm since I see no cut-out under the rear of the arm board.
Mass and damping are generally what are recommended - the two aren't always synonymous, the next thing for me to explore.
Old 24th May 2011, 10:04 AM   #36
Helmuth's Avatar
I will fit neutrick cinch bushes direct behind the tone arm on the top-plate to increase high end feel to it. And the hole for that have to be drilled soon.
I ordered a bearing set for the E50 motor. I damaged the top bearing when i performed a oil massage for the felt ring. The bearing was very brittle and broke.
Old 25th May 2011, 08:48 PM   #37
Helmuth's Avatar
The main switch has a capacitor to filter of disturbance.
It is 10nF the one in the TT was blow I replaced it. The official capacitor to be placed between line and neutral is a X capacitor. The capacitors who are official tested for this function have a UL or CSA label and X capacitor text.
On the photo the defective capacitor is easy to recognize. The capacitors are often the cause for fire in electronics!
File Type: jpg Schermafbeelding 2011-05-25 om 22.37.11.jpg (47.8 KB, 243 views)
Old 25th May 2011, 09:08 PM   #38
Helmuth's Avatar
To day I received new mushroom suspensions they are nice flexible It reduce the mechanical noise good when I place my ear near the TT.
Also made the cut out for the cinch bushes near the arm to have the wires without extra connection direct to the bushes.
Van den Hul: MCS - 150 M
It enhances the high-end looks and funtioning.
File Type: jpg Schermafbeelding 2011-05-25 om 22.36.45.jpg (57.6 KB, 240 views)
Old 26th May 2011, 06:59 AM   #39
Straight Tracker is offline Straight Tracker  United States
Default Hello Helmuth
[QUOTE]
The picture of the capacitor seems to indicate that its value is 10 pF. It looks like the "p" is mangeled to appear like an "n". Correct me if I'm wrong.
Sincerely,
Ralf
Old 26th May 2011, 10:12 AM   #40
Helmuth's Avatar
[QUOTE=Straight Tracker;2583937]
Sincerely,
Ralf
On the capacitor I read 10.000pF =10nF. But the exact value isn't that important in this application. It will cause a bit leakage-current and it is placed over the switch.
TD124 mk1 RB301 new plinth and serviceHide this!Advertise here!
Marantz CD17 KI MK1 Service manual wanted Fidelity Audio Digital Source 2 4th May 2013 11:11 PM
Service Manual for Rega Planet (mk1) squall2072 Digital Source 0 20th November 2005 07:11 AM
Thorens TD124 mk11 jonnypotter Swap Meet 3 8th September 2004 02:14 AM
Philips CD850 MK1 service manual anyone? tubenut Digital Source 2 26th August 2004 05:50 AM
Spectral DMC-20 MK1: Service Manual needed Blitz Solid State 0 2nd January 2003 09:21 AM
