TD124 mk1 RB301 new plinth and service
Old 22nd May 2011, 04:36 PM   #21
Helmuth is offline Helmuth  Netherlands
Helmuth's Avatar
So the plinth has dry up and I made the upper-plate to fit the frame, now a quick fit to see how it will look like.
File Type: jpg Schermafbeelding 2011-05-22 om 18.31.36.jpg (48.7 KB, 277 views)
( (( KUGELWELLE )) )
recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet
Old 22nd May 2011, 05:42 PM   #22
Helmuth's Avatar
Originally Posted by kevinkr View Post
Welcome to the fraternity. I'm running a Schick 12" arm with ZU Denon DL-103-1 on my restored TD-124/II - I'm pretty pleased with the performance. Slate plinth should finish it soon.
looks cool a slate plinth.
Old 22nd May 2011, 06:11 PM   #23
Helmuth's Avatar
I done a small angle to the top and bottom plate with the router.
TD124 mk1 RB301 new plinth and service-schermafbeelding-2011-05-22-om-20-09-49-jpg
File Type: jpg Schermafbeelding 2011-05-22 om 20.09.49.jpg (49.8 KB, 573 views)
Old 22nd May 2011, 08:30 PM   #24
Telemann is offline Telemann  Norway
A bit of perfection.
Old 22nd May 2011, 08:46 PM   #25
Helmuth's Avatar
Is that yours Telemann.
Old 22nd May 2011, 08:55 PM   #26
No, it's from OMA's site, but I really like this setup, and have been in touch with OMA about the plinth. They ship worldwide, with no breakage. Kevin has that tonearm ... it's superb. OMA's solution, with the tonearm mount separated from the chassis of the TD124, ensures a serious reduction in mechanical noise transmitted to the arm. I've seen measurements of 15dB reduction.
This one is mine, I had it painted in British Racing Green:
Old 22nd May 2011, 09:30 PM   #27
kevinkr's Avatar
Originally Posted by Helmuth View Post
The turn table seems to be stored a lot and not used a lot. So I do not aspect much wear of parts.
Cleaning and oiling things will do until other wise is proven.
Well that is what I thought about mine too, disassembling my unit which had probably less than even 100 hrs of use showed that there was a lot of congealed lubricant in the motor bearings - and no amount of oil is going to fix that. The old bearings can be cleaned and reused if not worn, and the result long term is worth it. I'm by no means the originator of this pearl of wisdom, but I have found the truth in it - five motors so far. The motor should run much quieter and cooler with a proper service even if you replace no parts.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 22nd May 2011, 09:33 PM   #28
Helmuth's Avatar
That arm goes along with the beogram 3000? Looks great minimalistic.
Old 22nd May 2011, 09:52 PM   #29
kevinkr's Avatar
<snip>
It's a very good arm and in fact my table and arm will be going into a very similar slate plinth (not OMA) for exactly the same reasons. I'll post a picture once it is finished.
Old 23rd May 2011, 08:40 AM   #30
It's the pro-version of the Beogram arm of the time, called the ST/P, 12" arm, for radio stations and studios. Very pleased with the soundstage it delivers, but believe it will do an even better job when mounted on a slate plinth, isolated from the TD124, I'm thinking of doing that - and did have a Schick in mind before Kevin got his (so not copying, Kevin - emulating!)
TD124 mk1 RB301 new plinth and serviceHide this!Advertise here!
Marantz CD17 KI MK1 Service manual wanted Fidelity Audio Digital Source 2 4th May 2013 11:11 PM
Service Manual for Rega Planet (mk1) squall2072 Digital Source 0 20th November 2005 07:11 AM
Thorens TD124 mk11 jonnypotter Swap Meet 3 8th September 2004 02:14 AM
Philips CD850 MK1 service manual anyone? tubenut Digital Source 2 26th August 2004 05:50 AM
Spectral DMC-20 MK1: Service Manual needed Blitz Solid State 0 2nd January 2003 09:21 AM
Copyright ©1999-2017 diyAudio
