TD124 mk1 RB301 new plinth and service
Old 21st May 2011, 09:54 PM   #11
user510 is offline user510
user510's Avatar
Originally Posted by Helmuth View Post
Really am I a member now good to hear that.
Nice looking turntables User510. What kind of improvements do you mean witch helped to let the TD124 sound better?
Regards Helmuth
re: member. Yup. Ownership creates an automatic membership. That way all "members" get to commiserate our triumphs and tradgedies.
re: improvements. That's a long list. And a lot of it is learning from what others around the web have done. I've chronicled my experiences with the TD124 at this link.
TD124 Dept
-Steve
Old 21st May 2011, 10:03 PM   #12
user510's Avatar
Originally Posted by Telemann View Post
Steve,
A question - how does one influence the push of the idler wheel against the step pulley? Is this adjustable - there is a certain amount of spring load to the idler wheel assembly, laterally towards the step pulley, but as the idler wheel also connects with the platter wall, I would think that the amount of push against the step pulley was important - in order to avoid any slippage.
@Helmuth - It really looks like someone took very good care of the deck you got hold of. A beauty!
Good question. What holds the idler wheel in position against the driving capstan and the driven inner platter rim?
See above image. There is a position adjust for the cam follower on the large arm. Additionally, there is a long tension spring (pull type) that serves to help retain position of the arm when speed selection is disengaged. That and the rest of the speed selector assembly which serves to position the idler wheel against the selected speed capstain on the step pulley.
I'll let the photos do the talking for me.
-Steve
Old 21st May 2011, 11:25 PM   #13
kevinkr's Avatar
First thing is to clean and lubricate the motor bearings - this will require disassembly - you'll find all of the information you need to do this on my thread.
I recommend replacing the motor bearings, and Steve (User510) sells good ones. Alternately if they are in excellent condition the originals may be used after a thorough cleaning and relube. The table will not be speed stable, nor get up to speed quickly if you do not go at least this far.
The 10nF cap should be replaced - look for one that is rated for across line service (X, Y or XY cap).
Resist the temptation to adjust anything until you have cleaned and relubed everything (bushings, linkages, etc) - if the turnable is not functioning properly due to lubricant age in most cases once this is addressed further adjustments often aren't required. You'll know once everything works freely whether that is the case. (It was mostly the case with mine, and several of the others I have worked on.)
Welcome to the fraternity. I'm running a Schick 12" arm with ZU Denon DL-103-1 on my restored TD-124/II - I'm pretty pleased with the performance. Slate plinth should finish it soon.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 22nd May 2011, 12:09 AM   #14
user510's Avatar
Hi Keven.
I haven't had any E50 motor bearings for sale since last October when I sold out my last batch. I have no plans to place another order. So it will have to be others who supply this kind of hardware.
-Steve
Old 22nd May 2011, 12:22 AM   #15
kevinkr's Avatar
Originally Posted by user510 View Post
Hi Keven.
-Steve
Bummer, I've used yours and a couple of others - I had more confidence in yours, but I will admit that the others seem to work just fine as well.
Thorens TD-124 E50 Complete Motor Rebuild Kit | eBay I've used these, they are NOT properly oil impregnated and need to be treated to a hot oil bath before installation or they will SEIZE. (Ask me how I know) These bearings perform very well once broken in.
Here is the other option: E50 Motor Rebuilding Kit for Thorens TD-124 Turntable | eBay I have not used this kit (yet) but have used a bunch of his other parts and so recommend this kit without reservations, and I believe these are ready to be installed without further work.
My experience with motors is that they can take up to 100 hours of running time to break in after a rebuild. I would recommend doing this before reassembling the table fully - and make sure it is WELL lubricated. (Check every day during the run in period) It may be wise to take it apart and clean and relube the bearings after run in - this is generally what all of the "professional" motor rebuilders do. Mine is now approaching 1K hours since the rebuild and I never have to adjust the speed.. EVER...
Old 22nd May 2011, 12:46 AM   #16
kevinkr's Avatar
Some points to consider.
1. Belts are not just belts. Their rubber composition and tension influence the speed, noise and stability of your deck. With one belt I have a whispering engine, but variable speed; with another I have a little engine whirr, but perfect stability and speed control; with a third I have reduced whirr, but some variation in speed during an evening's play.
2. Clean belts, pulleys, spindle wells, shafts - get rid of old oil, use new high viscosity oil.
3. Find a good balance between belt, the run of your drivetrain (after cleaning and lubing), and the position of the eddy pull magnet. You don't want the magnet interfering too much with the free run of the step pulley.
And here's a 64.000 dollar question:
My step pulley inside does not have the dark semi-circle of dark paint that one sees on a lot of step pulleys. I suspect this is paint that contains ferrous particles, to further increase the effect of the eddy pull magnet - but I'm willing to stand corrected. Someone's cleaned that off my step pulley.
I have several TD-124 and not all of them have the red dots or that inside coating on the intermediate (step) pulley.. The earlier units with the integral bronze bearing in the pulley do not usually have the dot, and may or may not have holes, and that semi-circular stripe - my II has both, but the I which I own and uses the same arrangement does not have the dot. The two pre 13K serial numbers I have been restoring (slowly and with hiccups along the way) do not have red dots or holes.. I'm not sure what the purpose of any of these materials is, but I suspect it might be to balance the pulley. The eddy current brake works by inducing currents in the aluminum disk and the less shrouded the magnet is the more current is generated which creates an opposing magnetic field which increases the drag produced by the brake.
Belts are critical on the II, and on later I with the intermediate (step) pulley bearings in the chassis. I have however also discovered that there is a reason why the stuff on the Schopper site looks so shiny - polish the running surfaces until they are as smooth as glass and you get a quiet running machine.
I run tight belts for speed consistency and maximum torque delivery - after all this is what the TD-124 is about.
The most consistent and best performing belts I have identified came from this fellow: THORENS-TD-124,134,135,TURNTABLE BELT -2 for one sale-- | eBay I have installed these on a 4 different TD-124 and they are consistently good so far. They are also the cheapest which just goes to show that the most expensive part may not be the best. I've tried a lot of belts including the OEM replacement which has the nasty habit of degrading rapidly and leaving goo all over the running surfaces. I still have one of the original 40+ yr old belts which is what I use for comparison and is clearly superior despite age to most of the belts I've tried.
The belt will stretch significantly in operation and eventually everything should get pretty quiet if the running surfaces are quiet enough.
The 124 (not the II) benefits from the installation of a motor mount upgrade kit here: http://cgi.ebay.com/Motor-Conversion...item5197f3d0ae The original mounting arrangement allow quite a lot of motor noise to couple into the chassis particularly if the mounting bushings have hardened up or are original.
Note that I have NO affiliation with any of these people and am just sharing what I use and have found to work.
The geltec bushings I am using may also be a worthwhile upgrade on the motor..
Old 22nd May 2011, 07:12 AM   #17
Helmuth is offline Helmuth  Netherlands
Helmuth's Avatar
The turn table seems to be stored a lot and not used a lot. So I do not aspect much wear of parts.
Cleaning and oiling things will do until other wise is proven.
( (( KUGELWELLE )) )
recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet
Old 22nd May 2011, 08:28 AM   #18
Helmuth's Avatar
I just took off the belt and idler wheel.
So I have cleaned the pulleys and belt and idler wheel. The inside of the non-machnetic platter were the idler wheel runs hat some sharper spots. So a sand it very loose with a very fine sanding paper and cleaned it so it had a flat smooth surface.
I cleaned the bushing and axle of the idler wheel oiled it again.
And mounted the assembly I can not see signs of wear on this turntable it bin hardly used.
On the idler wheel is a date it maybe say something about the age of the turntable. It says 3 september 1963 it means the table is made between 1963 and 1966. So it would be 48-45 years old. If it is the original one.
Old 22nd May 2011, 09:02 AM   #19
Telemann is offline Telemann  Norway
If you remove the motor capstan to apply oil to the top bearing, then make a note of where the capstan was on its shaft. The position of the capstan affects motor vibrations.
And don't trust the small libelle (level) on the deck. Check that it's true against a good level, used on top of the heavy platter (with the top platter removed). My small libelle was out of horizon by quite a few degrees. If they match, great - if they don't, go with the truer level, if affects drive train efficiency and spindle wear.
Old 22nd May 2011, 11:02 AM   #20
Helmuth's Avatar
Assembly plinth outside rim of 10mm birch plywood.
First tape the outside to each other. Then turn the inside up bring on the glue. Now fold it together.
To get it perfect 90 degree finish I lay in the bankirai plywood filling just for good fit.
TD124 mk1 RB301 new plinth and serviceHide this!Advertise here!
Marantz CD17 KI MK1 Service manual wanted Fidelity Audio Digital Source 2 5th May 2013 12:11 AM
Service Manual for Rega Planet (mk1) squall2072 Digital Source 0 20th November 2005 08:11 AM
Thorens TD124 mk11 jonnypotter Swap Meet 3 8th September 2004 03:14 AM
Philips CD850 MK1 service manual anyone? tubenut Digital Source 2 26th August 2004 06:50 AM
Spectral DMC-20 MK1: Service Manual needed Blitz Solid State 0 2nd January 2003 10:21 AM
