DIY Personal Turntable
Old 20th May 2011, 09:51 AM   #21
doitmyself is offline doitmyself  France
doitmyself's Avatar
Oups, sorry forgot photos
Old 21st May 2011, 04:42 AM   #22
Straight Tracker is offline Straight Tracker  United States
Default Hello doitmyself
Looking at the drawing in post #1, I noticed that the rod upon which the tone arm slides, is located well above the top surface of the vinyl LP.
Is there any reason why you could not locate the center line of that rod in the same plane as the top suface of the vinyl LP? If I understand the drawing correctly, that rod is the pivot for vertical motion of the tone arm.
Also, I would like to know the name of your CAD program.
Sincerely,
Ralf
Old 21st May 2011, 11:57 AM   #23
doitmyself's Avatar
Sincerely,
Ralf
Hi Ralf,
The only reason (I don't know if good or not), is that I wanted the gravity point under the pivot axe. I saw this in different forums, but about standart tonearms. The experiments will give me some answers.
And about the CAD program: Topsolid 3D by Missler software (version 6.10). You can download a viewer version (for free), so I can post you my turntable files, if you want. Here: ftp://ftp.topsolid.com/Public/TopSolidV ... 200.22.exe
Sincerely,
Bruno
Old 21st May 2011, 02:26 PM   #24
doitmyself's Avatar
The second problem I was worrying about is solved now. Yesterday, The receller from Omron, Mr Destra, came at home with the servomotor and servodrive. High quality material. THANKS Mr DESTRA.
We use this kind of motor in our machines at my company. And this model is much more powerfull. Many ways to pilot the motor. Here is a photo to show model and size.
Old 21st May 2011, 02:39 PM   #25
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Smallest Yaskawa servo motor is 30W, no ?
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 21st May 2011, 02:47 PM   #26
doitmyself's Avatar
Yes, that's this one .
Old 22nd May 2011, 05:46 PM   #27
dtut is offline dtut  United States
DIM,
Going by the parts you have already, your TT is going to be beautiful.
I'd like to share a couple of observations based on my experience building linear tracking arms. If you are going to use O rings in the arm you may find some of them are stiff enough to transmit noise. I've found that RTV silicone or something with a similar resilience works well both to keep parts aligned and damp noise. Heat shrink tubing on the arm is a great damper.
Six inches is about the longest arm I've had any success with, but I use ball bearings and have no experience with linear bearings. The problem is that the arm is trying to torque around the bearing contact point, which can cause non-linear movement that can result in sound distortion and skipping. If the linear bearings and the longer arm work well, that would be a major achievement.
Ralf,
The question of where to place whatever carries the arm - rod, tube, V trough, etc. - and where to place the arm itself is a nasty can of compromise worms. Shorter arms seem to work better, but that puts everything right over the record surface and makes record changing hazardous unless you use a high pivot. A high pivot is out of the way but results in a peculiar headshell/cartridge movement and a low pivot with a straight through arm can mean problems with CW placement. And there are further considerations for arms placed above or below the beam.
Eventually, I settled on a low pivot, overhead arm that is roughly equivalent to the alignment of an AR xa, but because my wife was reluctant to change records, I also built a sliding tower which moves everything to the rear edge of the record. There are photos on the last page of the "Opus Cantus linear tracker" thread.
If DIM's linear bearing or your own Straight Tracker solutions pan out, most of the LT compromises will be swept away. I'm looking forward to that possibility and hope for success for both of you.
Doug Tuthill
Old 23rd May 2011, 02:33 PM   #28
doitmyself's Avatar
Originally Posted by dtut View Post
DIM,
Hi Doug,
And Thanks for your support.
Old 23rd May 2011, 03:01 PM   #29
doitmyself's Avatar
DIM,
I don't know with what are maid my O rings, I have seen in the website of the company which sales us the seals that there are 4 differents materials. When the marketing person of this company will come here, I'll ask him for more details..
[/QUOTE]
[/QUOTE]
This is also a problem for me, I'm a total noob in arms. That's why your comments are welcome, If you see the main drawings, The arm pivot is just fixed by one screw, so I can adjust the distance from the LP's center, so I'll be able to make tests with different sizes and different arm material (aluminium, wood). About the linear bearings, I will also try to do a small video of the tests I want to do before? Actually, I'm trying to buy a second hand TT, not expensive, in order to dismantle it and take the arm for tests with onother TT (Technics Sl Q303).
[/QUOTE]
Old 23rd May 2011, 03:05 PM   #30
doitmyself's Avatar
I have finished another main piece this WE, the main shaft. See photos with bearings and seals.
DIY Personal TurntableHide this!Advertise here!
Personal Tube Amp DIY Project TexasAudio Tubes / Valves 27 11th December 2009 11:26 PM
DIY turntable using parts from DIY Hi Fi Supply gadfly Analogue Source 6 9th August 2009 04:59 AM
My DIY Turntable...... Paul Dimaline Analogue Source 3 24th April 2006 11:25 PM
DIY Turntable Posthorn Analogue Source 14 29th March 2004 01:10 AM
DIY turntable del Analogue Source 2 20th July 2002 09:26 AM
Copyright ©1999-2017 diyAudio
