2SK170 BL MC step up amp - Page 2 - diyAudio
Old 10th May 2011, 11:30 AM   #11
gpapag is offline gpapag  Greece
gpapag's Avatar
You can have it working safely with up to 25Vdc input.
http://www.alldatasheet.com/datashee...TI/UA7800.html
With the current you are drawing in this application, temperature rise would not be an issue.
George
["Second Law is a bitch." - SY] ["BTY my shop's large door is 14 feet wide so I can get my ego in each morning. Some evenings it can leave via the mail slot". -Ed Simon]
Old 10th May 2011, 12:30 PM   #12
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
35V max in. 9V drop x ~15mA = 135mW. No worries.
Old 10th May 2011, 12:46 PM   #13
smpkje is offline smpkje  Greece
You can use 78L09 as well.
Old 10th May 2011, 01:13 PM   #14
Salas's Avatar
Don't know how they internally bias the TO-92 equivalent but the datasheets give 27dB worse rejection performance than the TO-220 one.
Old 10th May 2011, 01:25 PM   #15
gpapag's Avatar
Dear Salas
With 35V in and 9Vout, Vdrop is 26V. This, times 15mA makes a 390mW.
Still not too high, but 35Vin is according to some manufacturers above from what they allow.
But I won't argue with you, because the nice schematic you provided before, is ideal for building a pre to be installed just behind the cartridge on the headshell.
I would like to try this.
But I am lucking the Fets.
Do you know any source in Athens?
George
Old 10th May 2011, 01:38 PM   #16
Salas's Avatar
I did not suggest he uses 35V input. He asked what is the max input. 35V absolute max is on the datasheet. 18VDC adaptor is OK.
Sometimes a couple of places like Fanos & Meni Kodoravdi take orders or have some left from adding a few to previews special orders.
Old 10th May 2011, 01:51 PM   #17
gpapag's Avatar
Thanks for the info. I'll contact them.
George
Old 10th May 2011, 04:15 PM   #18
Would V grade 2sk170 be ok for this ? I have about 12 waiting for a good use.
I will probably use with a Ortofon Vivo Blue (about 200 in the UK)
Thanks,
John
Old 10th May 2011, 05:39 PM   #19
Salas's Avatar
Yes, with R1=120 Ohm and circa 12mA IDSS each K170V.
Old 16th May 2011, 01:29 AM   #20
batty is offline batty  Australia
I have bought the remaining parts i needed and dug out an old 16V ac supply. I will need to build a bridge rectifier out of 4 of the diodes I have to get some DC to the 7809s. and a smoothing cap 4700 x 25v should do it.
Townshend Rock II, My new TT since 1986.
MC Step-up transformers mantisory Analogue Source 62 1st March 2015 04:53 PM
nuvistor MC step up reinhard Tubes / Valves 66 14th February 2014 01:27 PM
Selling JFETs - 2SK170-BL, 2SJ74-V Ruach Swap Meet 113 3rd March 2010 11:28 AM
FS: VSPS phono preamp & tamura MC step up transformers. rjm Swap Meet 0 25th August 2005 05:42 AM
What about 2sk369 in place of 2sk170 in MC phono patriz Pass Labs 2 24th February 2003 10:35 AM
Copyright 1999-2017 diyAudio
