Old 6th May 2011, 12:29 AM   #1
Json is offline Json  Singapore
Smile THorens TD125 MKI motor rotation problem
Hi all,
Need to seek some advise from you.
I had a TD125 MKI turntable having some issue with the rotation at 33rpm.
The good news is that the motor is turning. But the bad news is that sometimes, when you turn it ON it will rotate clockwise and turning it
OFF to ON again, it will rotate anti-clockwise. Its rotation toggle almost
everytime you power ON anf OFF again continually.
Anyone had that experience?
I notice that turning the speed to 16rpm then back to 33rpm do help to
correct the rotation problem. Also when in the ON state, changing to 16rpm,
the motor tumble and not rotating.
So far, I had changed only polarity E-Cap to new ones but no improvement.
What you guys think of this? Motor or other components on the PCB board issue?
Thank you very much.
Old 6th May 2011, 02:53 AM   #2
singa is offline singa  Singapore
Send a message via AIM to singa Send a message via MSN to singa Send a message via Yahoo to singa
Hi, you need to download the service manual from vinyl engine or something
similar.Could be mechanical or electronic hence the schematic will help.
Is there really a 16rpm mode?Thought 33 and 45 rpm only.
Old 6th May 2011, 03:54 AM   #3
Hi, Went to vinyl engine and saw the TD125 AB version service manual
and user manual.According to user manual the speed control is electronic
wien bridge controlled via switching some reistors and capacitors of small
value.Power to motor is provided by a push pull amplification stage.
The speed selector switch is connected or levered to a microswitch
which is fastened by screws.It is possible the assembly may have loosened
over time or be faulty (which I doubt but who knows).I think this is the only thing you can check as the speed is all electronics unless you are a electronic person yourself.
Old 6th May 2011, 05:25 AM   #4
Thank for your kind input and indeed I read all the info I can get from web.
However, I was seeking information from anyone here who had experienced this problem before or happen to know what is wrong.
I had been in the electronics manufacturing industry long enough (~20years) which allowed me to do some repair work on my own .
Old 6th May 2011, 06:22 AM   #5
Json said
Hi, All the more you should be able to fix it.
Old 6th May 2011, 06:56 AM   #6
Do everyone a favour if you do not have any good input to this thread.
Thank you.
Old 6th May 2011, 05:20 PM   #7
kevinkr's Avatar
Thank you.
Given that Singa gave you some pretty good input on where to go to get a service manual and then more or less complemented you on your probable ability to get this sorted out your above response seems unwarranted.
My useful input would be to go through the controller and replace all of the electrolytic capacitors in the controller. This version of the table was made from 1968 until about 1970 or so when the MKII replaced it and now the original electrolytic capacitors are very tired. I owned a MKI for about 10yrs and at a certain point it would no longer hold speed consistently and really lacked torque - all symptoms of bad capacitors. Specifically since you have the MKI it is most likely that the phase shift capacitor for 33.33 rpm is bad or the switch itself has oxidized contacts which can be fairly easily cleaned with a good contact cleaner. Does it exhibit the same problems at 16.67 or 45rpm or just this one speed?
Axial caps in all of the right values were still available from Mouser or Digikey last time I checked and presumably there are others sources more local to you. Probably the French made Vishay types are the most durable IMLE.
Take a look at Caig Labs products for a cleaner that works long term on the pcb based switches on your TD-125.
www.kta-hifi.net
Old 7th May 2011, 12:08 AM   #8
Hi, thank you for the feedback.
Perhaps, it was overlook by me that I did not mentioned that I did have the service manual and did study it before asking questions.
However, below is the list of actions taken so far
1) Clean the all the contact - DONE
2) Resolder all solder point to prevent any cold joint - DONE
3) Changes all E-Cap - DONE
4) Adjusted all voltage to required 8V, 5V and 2.5V respectively for 45, 33 and 16rpm. - DONE
5) Adjust frequency to center done for 45 and 33 (except 16rpm as it was not rotating or maybe rumble)- DONE
So far, the above mentioned was done and the motor is running very consistently with spot on 33rpm. But the 45 rpm was drifting slightly most of the time. But 16rpm was the worst which cannot rotate much.
So I believed that the electronics part were working.
However, when the motor is rotating, switching the speed control will most of the time toggle the motor to rotate in counter-clockwise(especially switch from 33->16->33) instead of remaining at clockwise direction. Then you have to play around with the ON/OFF switch or speed control switch to get it back to rotate in the correct direction.
This is the problem or all the while that is what I had been searching for the answer.
My guess was the weinbridge oscillator being trigger phase in and out of phase that causing the problem.
Any ideas what caused the motor rotation change direction?
Is it a weak or dying motor?
Old 7th May 2011, 09:38 AM   #9
hi, I did not mean to make fun or belittle anyone for that matter.
OK my 2 cents worth...from item 5 it is clear that 16 rpm does not work.
Since the input to the motor is common we can rule out the motor.
My first suspect would be the microswitch which contain 4 way double pole
switch as suggested in the service manual.Other than that as Kevinkr sugested it could be the phase shift caps.
Could be the resistors,being able to set the setup voltages does not mean
that the frequency is "set" as the value of the capacitance and resistors
determine the frequency of oscillation.Looking at the oscillator circuit the
switch selector connect parts of the oscillator as a whole so if part of the circuit is not engaged I think the oscillator will be open circuit.
I would check the capacitors out of the circuit if their values are within tolerance(small value film caps of the wein bridge oscillator).Same for the resistors and if they are ok then check the semiconductors.If drift is a problem then a scope will be useful.Note that if a motor rotates in opposite direction may indicate a change of polarity of current which may indicate leakage or reversal of polarity somewhere.
Old 8th May 2011, 09:28 PM   #10
Tubologic's Avatar
This is easy to check with a scope and the service data's.
YES, it is. This symptom is well know on the TD125 and the culprit is allways a defective motor. If the motor has the tendency to randomly start backwards with low couple and noisy (vibrating) operation don't search any further: replace the motor.
Thorens TD125 Motor, speed controller and power supply replacement Chris74 Analogue Source 21 1st November 2010 12:06 AM
Help for Thorens TD125 Turntable tiziano Analogue Source 12 13th September 2010 04:32 PM
Thorens TD125 Upset! soma89 Analogue Source 2 15th April 2010 05:05 PM
Thorens td125 issue? soma89 Analogue Source 1 7th April 2010 04:51 PM
Page generated in 0.14931 seconds (82.43% PHP - 17.57% MySQL) with 11 queries
