diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Analogue Source (http://www.diyaudio.com/forums/analogue-source/)
-   -   Grace G-707 headshell (http://www.diyaudio.com/forums/analogue-source/18793-grace-707-headshell.html)
Gram 10th August 2003 01:26 AM
The headshell of my Grace was accidentaly broken :( Do you think it can be satisfactorily glued up..? Any further suggestions..? Thanks..
fdegrove 10th August 2003 05:35 PM
A lot will depend on where and how it was broken.
You could try super-glue or something similar.
If it's metal maybe a dedicated metal glue will make for a better bond.
Just be careful not to put too much glue on it ot it will never sound the same again...;)
Cheers,:)
Brett 10th August 2003 08:30 PM
How was it damaged? If it was struck or twisted hard enough that the plastic headshell was broken, I'd also be concerned for the state of the bearings and/or the straightness of the armtube. A 707 is a good arm, but it's not exactly built like a tank.
Gram 10th August 2003 08:36 PM
Thanks for the replies. Something heavy was dropped on the headshell and snapped it where it meets the armtube, which appears straight. I guess a new headshell would be the answer, but I dont like my chances of finding one of those. I think glueing it, even if it appears successful, will probably have some adverse effect on the sound..
fdegrove 10th August 2003 11:15 PM
What do you expect?
See it as a temporary solution if you like....I got two arms, two legs but not two tonearms..I know, it's a very poor joke...
If it's a clean cut, as you suggest, use glue and save up for the next tonearm.
Cheers,;)
DSummer 11th August 2003 01:08 AM
Hadcock headshell
About 15 years ago, my friend change it to Hadcock headshell with huge sound improvements (a little modification is needed)
fdegrove 11th August 2003 01:27 AM
As far as tonearms go; Hadcocks are natural accidents, Graces are accidents waiting to happen....
Either way, you'd probably want a uni-pivot, just not one of those...
Cheers,;)
DSummer 11th August 2003 03:14 AM
The Hadcock shell can be ordered from manufacturer, but not sure the price... After modification, Grace 707 will give you a surprise!
ktigerb 11th August 2003 07:31 AM
Grace 707 Headshell
Greetings
I believe Dave (Planet10) has some expertise in Grace arm headshell replacements and "upgrades".! How about it Dave
I been planning a similar operation with a sturdier headshell but it will change the effective length somewhat , which is no big deal just have to measure and find correct Baerwald info for new pivot position.
regards
keith birss
Gram 15th August 2003 09:30 PM
Grace headshell
Thanks for your suggestions..I'll let you know how I got on..
Resources saved on this page: MySQL 18.75%
