Grace G-707 headshell
Old 29th January 2004, 11:37 AM   #11
chefboes is offline chefboes  Germany
Hi at diyAudio,
Ive got the same problem as GRAM - the headshell of my 707 got broken too. I think bearings and armtube are still allright, therefor repairing it should be worthwhile.
How can I contact dave (Planet 10 ???) to get more infos on changing the headshell (maybe a hadcock)??
Can anyone help??
Regards from Frankfurt, Germany
Old 24th June 2004, 01:58 AM   #12
fantasia is offline fantasia  Australia
Default Grace 707 headshell
Well, i had a Grace 707 some years ago!!!! i think i gave it away?? i think my friend might still have it??
Anyway i had the same problem with the headshell i used 5minute epoxy worked fine i'm sure with a metal headshell, it would be better.
A most underated tonearm, i ran it with a Grace F8 cartridge re-tipped with a Garrott micro scanner, tracked a record like a leach sounded very lush like a moving coil ( i'm sure i've upset someone now!!!!) well i later had an ENTRE Moving Coil retipped with a micro scanner and it sounded as good as that!!!!
Old 23rd July 2008, 11:47 PM   #13
Butch1970 is offline Butch1970  United States
Looks like I'm resurrecting an old thread here.....
Is the headshell on the Grace 707 replaceable? I have seen Grace headshells on eBay, but I'm not sure if they're for the 707.
Old 27th July 2008, 01:33 AM   #14
bulgin is offline bulgin  South Africa
Default Grace G-707 headshell
Hi Gram
Does it look anything like this? The arm here is a Grace G-727 Gyro Master. Mine isn't broken but I'd sure like another couple of them.
bulgin
Old 27th July 2008, 08:16 AM   #15
harwoodspark is offline harwoodspark  England
I have a Hadcock headshell on my Grace. A great improvement.
Si.
Grace G-707 headshellHide this!Advertise here!
Grace 707 help woody Analogue Source 16 11th February 2017 12:43 AM
WTB: Grace 727/747 headshell slydwz Swap Meet 0 28th June 2005 01:41 PM
Grace F9E Keithj Analogue Source 6 19th July 2004 10:23 PM
Grace 707 ingvar ahlberg Analogue Source 9 21st March 2004 10:47 PM
Copyright ©1999-2017 diyAudio
