SME 3012 series 2 value?
Old 9th August 2003, 11:26 AM   #11
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Thanks Frank
Old 9th August 2003, 11:42 AM   #12
Brett is offline Brett
Brett's Avatar
Originally posted by dhaen
Another colleague is giving me a 401 in plinth with arm.
I was thinking of re-plinthing the 401 and chosing the best arm.
I know the 401 is an acquired taste, but as it's there, and I seen destined to have one....so be it.
Cool. You could do a lot worse than a 401. A Linn for example.
My 3012 is currently on my suspensionless Gyro and sounds great with the Denon. I hope the bronze bearing is as good as I've heard.
Old 19th August 2003, 04:11 PM   #13
dhaen's Avatar
Default Update...
Just got my SME 3012 II. The guy accepted 100 gratefully.
It is boxed and has never been used!
Looks ideal for rewiring for balanced signal.
I also got my 401. Used, but VGC. It's got an arm that I don't recognise, fitted with a Shure V15 mk3. I'll post a picture when I get some time, and hopefully someone will recognise it.
Thanks for all the advice.
Old 19th August 2003, 04:20 PM   #14
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Great news John! Carving a plinth already?
cheers
peter
Old 19th August 2003, 04:23 PM   #15
dhaen's Avatar
Peter,
I have some ideas that would make Frank shudder
Old 19th August 2003, 04:35 PM   #16
Hamish is offline Hamish  Australia
Hamish's Avatar
Default On the topic of old SME's.........
I recently picked up a 3009 that seems to be a series 1. I can't seem to find out anything about it. The only obvious difference i can see is the anti-skating (but i've machined up a series II knock-off that does the job). Does anyone know if the dl 103 will go ok in this arm? Seems pretty heavy.......
Old 19th August 2003, 06:20 PM   #17
Brett's Avatar
Sounds good. What are they?
I hate people who get deals like that. Unless it's me of course.
Congrats. That's a great price, one you could probably quadruple on ebay in the right market. Don't though, it's a good arm and one you're not going to better except for a lot more money.
OTTOMH it's effective mass is somewhere around 11g so whether it will work with a DL103 depends on which 103. There are lots of models in the lineup with greatly varying compliance.
Old 20th August 2003, 07:32 AM   #18
ktigerb is offline ktigerb  South Africa
Hi Guys
401 Is that the one with rim drive rumble generator ?
regards
keith birss
Keith Birss
Old 20th August 2003, 07:52 AM   #19
analog_sa's Avatar
The combination of 3012/plain 103 is found to work very well by me and others. The 3012 of course needs to be rewired. 3009 (non-improved) also works, albeit marginally less well with 103.
As a friend in Singapore says about the 301: 'rumble king'. I've read cautions about using any of these pottery wheels indoors but their intrinsic musicality more than makes up for the danger
Old 20th August 2003, 08:16 AM   #20
Brett's Avatar
I know that's a good combo, as is the S (how I'm currently running), but the D is too compliant.
Soon (before 2006) I'll get the brass bearing and rewire mine, but there are a couple of projects before it in the queue, and it's not my main arm/cart.
I thought the 301/401 were going to be really awful, until I heard a 301/3012/103 and was very impressed.
SME 3012 series 2 value?Hide this!Advertise here!
re-wiring SME 3012 Karrry Everything Else 3 3rd May 2009 12:46 AM
Thorens TD 125 with SME 3012 Karrry Everything Else 14 30th April 2009 02:58 PM
SME model 3012 Series 2 BrianDavid Vendor's Bazaar 6 20th August 2008 08:53 AM
Sme 3012/2 Thago Analogue Source 0 3rd November 2007 10:28 PM
