Old 23rd April 2011, 03:53 AM   #1
jasonguitar's Avatar
Default Teac X3R reel to reel troubleshooting help
I have a Teac X3R that has a problem. I found this deck sitting on a curb completely intact a few years ago. I recently pulled it apart and cleaned, lubed, changed belts, demag-ed, etc. Transport works great. Direction controls work great. Heads are in nice shape. Plays back great. The problem it has is that when you first press play, a hum/buzz comes through the outputs but will abruptly go away at some point. Sometimes quickly, sometimes slowly. It will also come and go from time to time during playback. I found one burned up resistor across a relay so I replaced that but no difference. I figured it was dried up capacitors but I've replaced all the electrolytics in the power supply and about 80% of the caps throughout but the problem remains the same. Could a relay cause this type of problem? It seems like all the relays are functioning. Any tips?
Old 4th May 2011, 01:44 AM   #2
miklos is offline miklos  Canada
Could a relay cause this type of problem? ?[/QUOTE]
Most unlikely , but is the relay make a mechanical buzzing sound the same time when the buzzing is in the speakers? If it is, then maybe the power supply powering the mechanism is intermittently defective.
miklos
Sony TC-770-4 Portable reel to reel professional tape recorder for sale gaetan8888 Swap Meet 4 15th June 2011 12:58 AM
Average Durability of Vintage Original Reel to Reel Tape Albums? fredonian Analogue Source 10 8th September 2010 03:54 AM
looking for help diagnosing volume loss on tube amplified reel to reel player diblet Tubes / Valves 30 24th August 2010 02:45 AM
FS: Revox PR-99 Reel to Reel parts ralphs99 Swap Meet 8 30th June 2010 05:21 AM
Teac Reel to Reel mikje Swap Meet 0 30th December 2008 07:32 PM
Page generated in 0.07860 seconds (68.17% PHP - 31.83% MySQL) with 10 queries
