Old 17th April 2011, 08:46 AM   #1
Default Partridge D3061/SB Any info?
Hi, does anyone have any data on these 10:1 step up transformers?
Any good for Moving coil step ups?
OOpps double post sorry
Old 15th May 2011, 02:26 PM   #2
I don't know about them, but I am using the Partridge 977 (1:6 step up) and they are great. Available on ebay.co.uk too!
Visit www.tirnahifi.org!!
Old 15th May 2011, 02:33 PM   #3
It's a microphone step-up and sounds terrific with movin-coils.
Blue/Yellow in - Red/Brown out.
Old 15th May 2011, 03:25 PM   #4
Hi Thanks for the info, Do they have good bandwidth?
Cheers Steve
Old 15th May 2011, 03:35 PM   #5
Cheers Steve
I never measured them, but sonically they were up to the UK made Audio Note's (that I could suspect was use the same brand with quite a different price-tag.
They have always been highly regarded in even the most expensive studio equipment, are hand-wound on a amorpheos core and most of all have a solid mu-metal casing.
Cheers and congrats - they are being scarse on the market.
Peter
Old 15th May 2011, 06:14 PM   #6
Hi Fran.
I would agree totally on the Partridge 977s, i have been using them with a Denon DL103 with excellent results.
I was just curious about the D3061 as its a different style case to the 977s, hopefully the D3061s performance is comparable.
Plus the extra gain would be usefull.
Cheers, and thanksa
Steve.
Old 15th May 2011, 08:32 PM   #7
Hi Fran.
Cheers, and thanksa
Steve.
Old 15th May 2011, 08:52 PM   #8
35:1 is often the way to go when choosing a MC-sterup trafo. But a turn-ratio of those dimensions take the breath out of the designer (and the coil-winding and core-metals at hand).
10:1 may certainly be seen as a noisy solution - but it's always the pick of the best apple soundwise.
Old 18th May 2011, 05:53 PM   #9
Hi
Well i tried some of these transformers, and the result was very poor! ie zero low frequencys!
BLue /Yellow winding measured 60ohm and Brown/Green winding mearured 2.6ohm
Which says to me brn/grn is input, Confused.
Old 18th May 2011, 06:04 PM   #10
Mmmm. On the 977 the input measured 25r and the output 250r. Something not right there. Maybe it's an impedance mismatch and you need something else..
Partridge D3061/SB Any info? velvetsunrise Analogue Source 0 17th April 2011 08:36 AM
Partridge Transformers vyju Tubes / Valves 5 17th February 2011 07:12 AM
Partridge Vs Edcor M Gregg Tubes / Valves 16 18th December 2010 05:44 PM
Partridge audio output transformer value bentoronto Tubes / Valves 6 15th February 2009 04:36 PM
Partridge SE O/P transformers Stef Tubes / Valves 0 30th July 2007 08:42 AM
Page generated in 0.10547 seconds (76.87% PHP - 23.13% MySQL) with 11 queries
