Old 9th April 2011, 12:37 AM   #1
Default Arm / cartridge advice please!
Greetings all,
I have recently dug out my LP gear after many years of storage. I have a couple of hundred LP's that need cleaning thoroughly (mould, argh...), plus a UK made "Systemdek" player- belt drive, glass platter, early Rega RBIII type arm fitted with an ATF3 MC that needs replacement. I built an Elektor low o/p MC headamp for this in 1992.
I also have (in original box!) an SME 3009 S2 improved from about the late 70's that I retired on buying the Systemdek. I used a Shure M75ED MM. My question is, given I need to buy a decent new cartridge for the Rega (I am thinking ATF3 or similar again), is it worth investigating use of the SME arm (and a new MM cartridge?) What is current thinking on arms like the SME (and the necessary high compliance cartridges) vs the basic Rega? My CD player is a Sony CDP308 circa. 1987 (still going strong...).
Thanks!
Old 9th April 2011, 10:50 PM   #2
kevinkr's Avatar
This question might find a better answer over at Vinylengine.. I'm not familiar with the RBIII but would suspect that a 3009 S2 Improved on the right table and with the right cartridge might be an improvement. Note that there are lots of upgrade tweaks available for the S2 Improved as well.
www.kta-hifi.net
Old 9th April 2011, 11:34 PM   #3
Many thanks for the tip. I'll give Vinyl Engine a try. I'd like to give the SME another shot as it's a lovely piece of engineering. Cheers,
Tim.
Old 9th April 2011, 11:49 PM   #4
kevinkr's Avatar
Tim.
Indeed it is, I have several Series II.. (Unimproved)
www.kta-hifi.net
JH (Mayware) Formula IV Arm Advice FNQ Analogue Source 9 27th February 2011 10:42 PM
Advice on new cartridge simonl8353 Analogue Source 6 30th August 2008 05:33 PM
Combination tone-arm + cartridge??? Klimon Analogue Source 2 22nd May 2008 01:49 PM
arm- cartridge grounding phowell1 Analogue Source 7 11th November 2004 02:30 PM
fixing the cartridge to the arm solidly -- with glue (works for me) eila Analogue Source 3 7th May 2002 03:26 AM
Page generated in 0.07026 seconds (80.19% PHP - 19.81% MySQL) with 10 queries
