| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
hi everybody
Please, I wish to know if the following motor is good for turntable drive duties. Itīs a reel motor, salvaged from an old Akai GX-255 Rīto Rī. Outer rotor, Eddy Current type. Four wires -and no servo input at all-, operated with 4uf cap to provide phasing. 930 rpm@50 Hz, 1120 rpm@60 Hz. Currently, Iīm running it from the mains, with a 40 volts AC transformer and 4uF phase capacitor. It has adequate torque, and is incredibly smooth and silent, but it has noticeable speed drift. I managed to make a pulley for it, but I cant make it run the platter at 33rpm for a long time (in my diy thread driven TT...) Itīs a strange affair: I donīt know if its 2 or 3 phase; and is evident that is not synchronous... Is feasible to drive it electronically without a lot of expense or complexity? the motor looks like this: and that is the tt that iīm using for test duties: a frankenstein using an hybrid platter (strobo dotted from an old DD, plus steel outer ring to add mass and inertia) -more than a turntable, a tweakerīs platform...- Cheers!!! |
#2 |
frugal-phile(tm)
You are going to have to attach the 1st image... from the URL it is in your google mail/ None of us can log into your email to see it.
w dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
this is the motor...
#4 |
This is an induction motor, but I can't really tell how similar it is to a Papst Aussenlaufer motor, but I suspect it might be worthwhile to come up with some sort of eddy current brake like that used on the Garrard 301 or TD-124, the idea being to load the motor down sufficiently that small variations in loading don't cause a very significant speed change.
My TD-124 runs about a 0.5 - 1% slow depending on ambient temperature when stone cold, but it does come up to speed pretty rapidly, and once fully warmed up does not drift at all. (This takes about 10 minutes in a room at 15 - 20C.) I would try some sort of eddy current brake and somewhat higher voltage and see if the speed stability is not better.
www.kta-hifi.net |
#5 |
hi, Kevinkr.
Yes, the motor is some kind of induction motor turned inside out, and now iīm realizing that it shows the behaviour tipical of that kind of motors... The platter of my TT is partly steel, so a magnetic brake is doable without much trouble: I think that for now I will be using some neodymium magnets from a hard drive, and a threaded mechanism to tune it ![]() I have tested, a lot of motors. One of the best is one very simple synchronous that I made using a microwave oven motor (tray motor): I dissasembled the geared mechanism, putting a spindle in the magnet, a pair of oilite bushings and a metal/wood structure to contain the device. I will post a pic soon. Another excellent motor is one salvaged from an old changer: is a mixture of induction motor and synchronous motor, nicely machined. The rotor is squirrel cage type, but has attached a permanent magnet... It has excellent torque, and very good speed stability. But the Akai motor that originated this thread is smoother, devoid of any kind of cogging, and I wish to use it too. As you have noted, it has some reasemblance with the Papst outer rotor, but with four wires instead of three... Cheers! |
#6 |
salvaged motors: itīs a pity that those marvels end up as landfill...
#7 |
more pics...
#8 |
this one is from an old changer, part induction, part synchronous: as crude as it is, it shows excellent torque and very good speed stability. Also very silent:
#9 |
this dc motor was taken from a HP printer. Nothing fancy, but is powerful and surprisingly silent. Iīm using it with a very simple L200 variable voltage PSU: not the last word in stability (there is a little drift, +/- 1% in an hour or so), but no severe wow or flutter.
the part is C2162-6006 HP / (Mabuchi Small DC motor) |
#10 |
this beast is from the same reel to reel whose spool motor originated this thread...
itīs a servo AC, for capstan drive. Eddy Current, outer rotor. Iīm thinking of making a servo for it, looks very promising. |
| Looking for Akai 625 reel to reel user manual | floridaclear | Swap Meet | 2 | 5th January 2011 02:29 AM |
| Akai Reel to Reel Motor lubrication | daniherr | Analogue Source | 0 | 23rd April 2008 08:05 PM |
| Akai reel to reel Gx 4000D | BruceAlbert | Swap Meet | 0 | 2nd January 2008 01:40 AM |
| Akai reel to reel repair experts needed inside | CBRworm | Analogue Source | 6 | 3rd November 2007 11:24 PM |
| Akai GX-636 reel to reel | coondog | Analogue Source | 0 | 17th February 2007 08:03 PM |
| Page generated in 0.11374 seconds (80.82% PHP - 19.18% MySQL) with 11 queries |
