| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
Hi all, I am a new member and have just started trying to fix an old Roberts Radio. I wonder if anyone can help me? I am after circuit diagrams/service information of a Roberts radio type r700? If not are there any fm receiver circuits from other manufacturers that might use the af180 and af114 germanium transistors available? Perhaps these circuits could give me a push in the right direction (by the way the FM is dead on this radio!) Thanks.
#2 |
hi valvesrock
someone on this site may help you UK Vintage Radio Repair and Restoration these radios were great worth the effort. transistors types AF114/5/6/7 with the 4 connections have a bad habit of going short between collector case and screen, if this happens snip the screen connection usually works.
regards bob |
#3 |
Any electronic device between 20 and 40 years old needs all the electrolytic capacitors replaced. These look like oil tanks for model trains, covered with cardboard or plastic cover with a plus on one end or a minus on the other. If your unit doesn't have tubes (valves in UK) then it shouldn't have any upright aluminum can electrolytic caps with 2-4 sections. These would need replacing,too. I recapped a 1980 radio I inherited from my father, and it works pretty well. It has better sensitivity than the pocket Sony FM radio I bought 3 years ago. I didn't have a schematic.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,SP2-XT's, T-300 HF Projs, Steinway console, Herald RA88a mixer, Wurlitzer 4500 |
#4 |
Hi valvesrock
You've got PM (Private Message) On the top right of this page, under your user name, click on the "Private Message") ![]() Regards George
"Second Law is a bitch." - SY Last edited by gpapag; 20th March 2011 at 08:40 PM. |
| Pioneer CS-R700 horn speakers | limono | Swap Meet | 1 | 27th March 2009 01:44 PM |
| Modding Roberts/Akai mono block tube amps | limey222 | Tubes / Valves | 4 | 2nd December 2006 07:50 PM |
| Roberts/Akai M series amp problems | wboyd | Tubes / Valves | 3 | 1st December 2005 03:49 PM |
| Samsung AV-R700 service manual wanted! | stef1777 | Digital Source | 3 | 18th October 2005 03:23 PM |
| John H. Roberts DIY project in 1985 Audio Magazine | coolohm | Parts | 0 | 28th June 2002 05:28 PM |
| Page generated in 0.21511 seconds (34.20% PHP - 65.80% MySQL) with 10 queries |
