Many DIY turntables around ?
Old 8th March 2011, 11:34 PM   #1
Gutty is offline Gutty  Australia
Default Many DIY turntables around ?
Hey guys, like the title says, are many people making there own turntables ? And i don't just mean plinths...
I recently finished my own DIY TT. It uses a pro-ject motor, Audiomods arm, and a Rega bearing. The rest is pretty much home(work) made.
My main reason for asking the above question, is i'd like to know what bearing people use. I'm sure i can do better than the Rega, but at the same time don't want to fork out mega bucks for a schue(sp?) bearing.
Cheers
Matt
Old 9th March 2011, 01:09 AM   #2
djn is offline djn  United States
djn's Avatar
Here is the one I just finished.
http://www.diyaudio.com/forums/analo...iy-tt-pix.html
Old 9th March 2011, 02:53 AM   #3
Nanook is offline Nanook  Canada
Nanook's Avatar
Default bearings used in DIY tables?
Many are available out there, via the Internet. Or make your own. Depends on what you want. Personally I'd rather use a known bearing design and have it made brilliantly (as in "do the basics brilliantly"). By that, I mean perhaps a Rega style bearing (or whatever you wish), but machined by a local guy to the best possible finish. Or check out EpAY, etc.
One bearing design I really like is the Roksan, as used in the Xerxes series of tables. Long, small diameter, highly polished. Everybody has their personal favourite.
Your plinth looks great. Is it acrylic?
stew -"A sane man in an insane world appears insane."
Let's help Ruth and Dave
Old 9th March 2011, 03:00 AM   #4
kach22i is offline kach22i  United States
kach22i's Avatar
Harward Audio....................your prototype for bigger dreams?
Very nice.
Tubes and Martin Logan's
Old 9th March 2011, 03:03 AM   #5
Cheers Nanook. Yeah the plinths are acrylic.
I can make a bearing myself I guess, but not too sure on a design/specs etc
Old 9th March 2011, 04:08 AM   #6
vinylkid58 is offline vinylkid58  Canada
vinylkid58's Avatar
Wow, such a lovely table deserves a better bearing. With a relatively light platter (acrylic?), machining a decent bearing shouldn't be a problem.
I dig the micrometer VTA on that arm.
Nice work Matt.
jeff
Old 9th March 2011, 04:10 AM   #7
Very nice.
Cheers. Nah not really. I'd probably be happy to make more if people were to ask, but not like I'll be marketing it. Can't deny I'm proud and like showing it off though ;-)
Old 9th March 2011, 05:03 PM   #8
Nanook's Avatar
Default better bearing...
[QUOTE]Wow, such a lovely table deserves a better bearing. With a relatively light platter (acrylic?), machining a decent bearing shouldn't be a problem. /QUOTE]
Jeff, regardless of the mass of the platter, the quality of the bearing is a separate issue. Mass will have an effect on the thrust portion of the bearing, but not the lateral. I think this is why the brass sleeve/ball bearing type is used as much as it is.
Gutty, if I had the capabilities, I think I would bore the rega bearing out and press in a sintered bronze bearing. The design should allow for at least the minimum film thickness of whatever lubrication is available in the sintered bushing.
Of course if you want to get fancy there are several here that have made a magnetic "levitation" bearing. THe simplest bearing seems to be a Garrard or Thorens style grease bearing, where the grease actually helps with speed stability. Think of it as a self-dampened (rotationally) bearing. It does increase the drag on the platter, but does help with stability.
Old 9th March 2011, 05:13 PM   #9
dtut is offline dtut  United States
Matt,
Beautiful TT - you have every reason to want to show it off. The more I play with this TT stuff, the more I appreciate classic designs with good proportions and clean, simple lines. Oh, yeah, and that micrometer - another idea to steal. Thanks.
Doug Tuthill
Old 9th March 2011, 05:20 PM   #10
djn's Avatar
Forgot to add that you did a very nice job on your TT. Looks beautiful. I really like the looks of the arm.
On mine I used the Rek-O-Kut bearing. I was meant to spin 24/7 in radio stations. the thing is bullet proof.
Many DIY turntables around ?Hide this!Advertise here!
My Turntables and DIY ET-2 tonearm board records33 Analogue Source 15 27th October 2010 03:13 AM
Diy laser microphones and turntables ionomolo Analogue Source 16 1st May 2008 04:00 AM
my DIY Turntables and DIY tonearm Roger Waters Analogue Source 57 22nd January 2008 06:05 PM
AR Turntables DIY anyone want them? Zero Cool Swap Meet 5 14th May 2007 06:34 AM
