I purchased this on ebay for $100. After replacing the main drive belt the deck works fine except that it can't recognise a type 1 or 2 tape and hence can only auto calibrate a metal tape. The detect switches are working ok so it must be a dry joint or HR connector. The wiring loom looks really messy and ditto everything else inside.
Is there anyone who owns one of these beasts that's done a service and might know what common faults there are to look out for.
vhf man:
where'd you get the belt? i 've got one of these i'd like to get going again, too. needs a belt and a pinch roller.
mlloyd1
edit:
never mind, i found some info here:
Aiwa AD-F770 belts, which goes where - Tapeheads.Net
mlloyd1
edit:
vhf man:
mlloyd1
edit:
And here too..
Tape Deck Belts: Aiwa
Good luck with the restoration
