| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
Here is part of Kenwood C2 preamp schematic. This particular flat amp seems to limit/clip input signals with levels exceeding 500mV. This number is an estimate since at the moment I do not have an access to test equipment. It appears not to limit signals with "consumer" levels of -10db. However anything above -4db is clipped. Clipping is symmetrical as far as I can see in the wave editor. The components are: Q5, Q6 - uPA68H Q7-Q10 - 2SC1845F IC2 - NJM2041. Supply voltage is +/- 18VDC. All DC voltages are as referenced in schematic. Seems to me it is something relating to BJTs in cascode. Just can not grasp it. Any idea, please? Thanks |
#2 |
Q5, Q6 - uPA68H (N or M) with Idss 9 ~ 18mA.
#3 |
Turned out there is nothing wrong with it. Something else was broken.
| Recovery from clipping, soft clipping | hahfran | Solid State | 49 | 23rd February 2010 01:03 AM |
| How do I turn an high current signal into a line level signal?? | sardonx | Tubes / Valves | 8 | 27th August 2005 11:16 AM |
| Creating a differential signal from a single-ended signal for bridged amps | Peter Daniel | Chip Amps | 45 | 8th November 2004 12:47 PM |
| V/I Limiting | richie00boy | Solid State | 17 | 29th August 2004 03:25 AM |
| Hard clipping a guitar signal | Skankadellic | Instruments and Amps | 4 | 22nd January 2004 02:29 AM |
| Page generated in 0.07271 seconds (65.52% PHP - 34.48% MySQL) with 11 queries |
