Old 11th February 2011, 08:19 PM   #1
msdin is offline msdin  United Kingdom
Default PCB layout based on the Linn Intek Phonostage
Hi.
I've just finished laying out my PCB for a Linn Intek based phonostage and I would like some feedback regarding it layout.
Old 15th February 2011, 01:38 AM   #2
singa is offline singa  Singapore
Send a message via AIM to singa Send a message via MSN to singa Send a message via Yahoo to singa
Since you have laid out symetrically why not put SW1 down in the
center? (shortens the input trace and make the rest even)It might also be good if you can do a ground pour instead of the many parallel ground return or star ground.(red). singa
PS the mounting holes look too close to the edge of pcb,might be good if you allow more
clearance between trace and hole that means making the pcb slightly larger and for mechanical
soundness or strength as pcb may crack when screws are tightened.
Old 12th January 2012, 04:06 PM   #3
Hi, I'd just made your phonostage intek in precisely with your Jpg, but some transistor 560 getting very hot and voltage from symmetrical drop, can you helpme for this, or may be something wrong at your lay out.
Linn Intek Schematic required burbeck Solid State 41 25th September 2011 03:29 PM
My very first PCB layout - INA217-based mic preamp was the victim 454Casull Analog Line Level 4 27th June 2009 05:27 PM
linn intek DC on output??? hemiharper Chip Amps 0 3rd May 2009 02:12 PM
PCB layout for phonostage robmil Solid State 13 14th January 2009 02:22 PM
Linn Intek Volume Control Problem Grainger Solid State 4 2nd October 2006 04:23 PM
Page generated in 0.07456 seconds (65.56% PHP - 34.44% MySQL) with 10 queries
