LINN Axis Turntable Motor
Old 6th February 2011, 07:21 PM   #1
DocTony is offline DocTony  United States
Default LINN Axis Turntable Motor
Need help on the Linn Axis Pully Motor:
Initially I found that the motor has a hard time starting up. Even with turning the platter by hand, it only revolves a short time and is slow on 33rpm, then stops and little to none on the 45rpm speed.
I have replace ALL electrolytics caps, replaced the R1 resistor with an uipgraded thermistor and the rectifier also upgraded, new drive belt and re-oiled the subplatter well as recommended by a Linn service person.
Still the platter does not rotate freely and eventually stops. The motor has a vibratory noise and sometimes starts backward.
Is the motor shot or some other parts needs replacing. Please help. Thank you
Tony
Old 9th February 2011, 09:10 PM   #2
telecine is offline telecine  United Kingdom
I think the clue here is that sometimes the motor runs backwards. This suggests that you have probably lost one "phase" from the Axis PSU. Get a meter on AC volts across the two phases and I think you will find either one of them absent, low in amplitude, or distorted.
The cause of this is most likely in the output stage itself. Probably a BUX85F.
Do you have a scope?
If you have one phase absent, I'd check the o/p transistors on ohms range and replace as necessary. It may be prudent to replace the associated drivers at the same time. BC184?
This circuit is a bitch to fault find on, and please beware as it is not isolated from the mains and will bite if not treated with proper respect.
Old 20th April 2012, 06:37 AM   #3
ears12000 is offline ears12000
Default Linn Axis motor
Where can I find a diagram of the motor supply?
Old 22nd April 2012, 01:56 PM   #4
h_a is offline h_a  Europe
h_a's Avatar
Linn Axis Owners Manual, Service Manual, Schematics, Free Download | Vinyl Engine
Keep that in mind - the circuit directly rectifies mains without a transformer...
Hannes
High Octane phono preamp Wiki
LINN Axis Turntable MotorHide this!Advertise here!
Repairing Linn Axis Motor Drive Amplifier John Caswell Analogue Source 62 22nd May 2018 06:36 AM
Linn Axis Schematic beamish Analogue Source 12 20th February 2016 08:06 PM
Linn Axis psu almost fixed (i think!) martiny Analogue Source 0 4th March 2009 03:14 PM
Linn Axis PSU smoking martiny Analogue Source 0 1st March 2009 12:06 AM
Repairs to Linn axis turntable charlesrobinson Everything Else 1 13th July 2007 05:01 PM
