| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
I am replacing some 2sc458 NPN transistors with 2sc2240 in a tape playback amp. And wonder about the grades to use. On the schematic the hFE grades for the 458 are C 160-320 and D 250-500. For the 2240 the grades i have are GR 200-400 and BL 350-700.
Should I replace with GR or BL? Higher hFE would give more gain or? But then would this through off the eq? Or am i bass ackwards again? Does it matter as i will have to set the PB level and EQ anyways? FWIW the 458s i pulled measured 200+/-10 on my multimeter. I know that is not an accurate way to measure, but it could be used to group them. The 2240s come in at 200 +/- and 400+/-. Thanks for any advice. For reference here is the PB circuit, i marked red circles on the in and out |
#2 |
It's not critical at all. Looking at the grading numbers, I'd go with the lower gain units.
#3 |
Certainly safer from the standpoint of stability..
www.kta-hifi.net |
#4 |
Thanks for the help. Lower gain it is then.
| hfe on multimeters | pdul | Everything Else | 4 | 22nd February 2010 05:33 PM |
| Measuring Hfe | DreadPirate | Equipment & Tools | 7 | 29th January 2010 09:15 AM |
| Complementary vs NPN / NPN | toptip | Solid State | 1 | 11th February 2008 03:31 PM |
| Hfe PNP / NPN Distortion, Oscillation? | Zero Cool | Solid State | 15 | 14th January 2007 02:06 AM |
| looking for dual npn and dual npn smt transistors | sovadk | Solid State | 9 | 25th August 2005 10:58 AM |
| Page generated in 0.07820 seconds (70.98% PHP - 29.02% MySQL) with 11 queries |
