| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
My Technics SL7 Direct Drive Turntable works intermittently. For example, when I press the starter switch (after the player is powered) its turntable momentarily rotates and stops. Some times, when you press the starter switch, it works perfectly, but most of the time the turntable momentarily rotates and stops.
Since, it is a direct drive TT, I do not think it has a belt drive. Is it due to poor electrical contacts or defective switch. Can DIYer help me to overcome this problem? Cheers
#2 |
the problem with many of the DD turntables (heck - just about any late 80s mass turntable belt or otherwise) is the extra complexity. Cracking open my old Hitachi L55 to fix a problem was a nightmare with the speed controllers, servos, and whatnot in there.
It _could_ be a defective switch... or perhaps an aged capacitor? or bad solder joint or cracked PCB. Maybe it's time for another turntable or else you'll have to get in the Technics and start measuring and experimenting. |
#3 |
You don't indicate the age of the TT but I will assume it has a good number of years on it. I would do the following:
1. VinylEngine has the service manual - download it 2. Get a list of all of the electrolytic caps in the power supply & order them & replace them. 3. Clean all of the control pots and board interconnect pins with DeOxit 4. If the problem persists see if the service manual troubleshooting guide addresses your problem...if yes follow the instructions. 5. Still no luck come back here with what you have done & found & seek further guidance.
Kevin(ahcc20)...I'd rather have a bottle in front of me than a frontal lobotomy! |
#4 |
Dear Kevin & Kstagger
Thanks for your response, it was one of the award winning TT produced by Technics in 1983. Upto now it was working flawlessly, except changing the arm control belt. It's a linear tracking, DD turntable. Sound seems very good. I have down loaded the service manual, I will go through it and see whether there any troubleshooting pertaining to present issue. The specific problem is when I press the start button, the turntable rotates momentarily. Some time it works, but most of the times it doesn't. Thanks for your kind response. Best regards
#5 |
I have owned Technics SL-7 and SL-10. Of the two, my fondest memories are of the SL-7.
Have you had a look under the hood? The most likely fault with intermittent operation is poor (or intermittent) electrical continuity somewhere. The first I would suspect is a solder joint failure on the PCB assembly. See the following links for more info and pics: Soldering - Wikipedia, the free encyclopedia Failure in solder joints
Shaun Onverwacht |||||||||| DON'T PANIC |||||||||| |
#6 |
Dear Shaun,
Thanks for your suggestion, I am going to check the PCB connections. Also, I will clean all the connections and revert back. I really appreciate your support given to fellow DIYer. Cheers
#7 |
IF I recall correctly, that table also has two small idiot-proofing
switches. In the back of the platter area there is a switch that senses the edge of the record and one that senses that the player is closed. Be sure to check and clean those. |
#8 |
Dear Number 13,
Thanks for your suggestion, I will make sure to clean these switches to see whether the TT will operate smoothly. Kindly let me know your referred switches are the sensor slits on the platter? or something else? I checked, I find some slits (six no) on the platter located symetrically. Kindly advise me. Regards Mohan |
#9 |
The sensor slits on the platter tell the table what size
record is being played. The likely culprit, the "cover closed" switch is at the back of the player. It is easy to get to once you have the bottom off. |
#10 |
Dear Friend,
Thank you for your detailed explanation. I will take into account of your suggestions when I troubleshoot the TT. Yesterday, I cleaned the all switch contacts using camera lens cleaning liquid, I found the TT was working without a problem, I have not come to any conclusion yet, I will continue to check the TT operation for few days. I will revert back. Cheers
| Technics 1200 tonearm troubleshooting | tuffstuff | Analogue Source | 6 | 4th June 2009 06:54 AM |
| Technics Sl7 | baiston | Analogue Source | 1 | 26th November 2005 01:25 PM |
| Technics SL7 turntable | mr.tranzistor | Analogue Source | 1 | 5th April 2005 12:09 AM |
| Troubleshooting Help | wes-ninja250 | Solid State | 1 | 12th February 2005 07:22 AM |
| Troubleshooting Technics SA-310 | DcibeL | Chip Amps | 6 | 26th August 2004 09:50 PM |
| Page generated in 0.10023 seconds (86.09% PHP - 13.91% MySQL) with 10 queries |
