Catridge alignment / overhang gauge? Who uses one? - Page 2 - diyAudio
Old 5th January 2011, 12:48 AM   #11
The Denneson was a great tool, so if the Clearaudio is based on it, I'd say you're looking at the Gold Standard. I use one made by DB Systems but it was made in the 70's and I'd be shocked if it's still available. I believe that there may be something available from REGA since I do know they prefer different null points than usual. The choice of null point is not critical in my opinion, but there you go; there's more than one school of thought on the matter, for what it's worth.
I don't know about Windows or Linux printers but on MacOS when you set Global preferences at (OSX 10.6 used in this example; but it's similar on every version of MacOS going back to System7):
System Preferences: Language & Text: Formats
... you see a drop down menu at: Measurement Units where you are given a choice of US or Metric. I use all three OS's but always print any critical documents on MacOS.
If you live in North America, choose US, even if you are in Mexico or Canada and use the metric system, or live in the US and prefer Metric for some other reason. You may find if you selected "Canada" or "Mexico" when you set up the machine, that it's set automatically to Metric already. Change it at this preference pane.
The reason is this will set the standard printer default paper size to US Letter, which is the standard size of paper reams you buy for printers in these countries. Finally, be sure US Letter is selected (it will be the default, but you might have changed it) in print dialogs at 100% as well (because that's the paper you will have on hand) and it will always print exactly the correct size on the printer.
This should work as well in Linux since it also uses the CUPS print system that OSX uses, but I don't know that for sure ... I just let Linux print whatever it wants since it will be documentation only, not graphics, photos or some other dimension critical need. It's worth checking out in Windows; it may solve your problem, but again I don't print dimension-critical documents in Windows so I don't care and don't know for sure.
Similarly, if you live in the UK or Europe and buy paper in A4, be sure to choose Metric @ 100% even if you prefer inch measurements; same thing it will always print exactly correctly.
A lot of the time people choose one or the other because they are thinking of the defaults in an application they will be using; CAD or perhaps home construction, for example. They think they can jsut change it in the print dialog, but now you are relying on the printer's software and drivers to get it right, and they don't always.
Even if you do work with dimensions in some particular application, these apps will always have both options so don't worry about it. Simply set it according to what the prevalent paper you buy is (for Staples/Wall Mart paper, you usually have no choice; you get what the prevalent paper size format where you live is. An architect in North America might buy his paper in A4 but you probably don't; similarly US Letter is unheard of outside North America).
" ... Go back to the beginning of a technology before the priesthood was established; that was the time when people were communicating information, not proving why there needs to be Priests. This is why the old texts tend to be so good. ..."
Old 5th January 2011, 12:57 AM   #12
Irakli is offline Irakli  United States
Irakli's Avatar
I am using this and I'm happy. Good for Azimuth adjustment too.
Turntable Basics. Turntable Belts, Parts and Accessories.
My System
Old 5th January 2011, 01:36 AM   #13
Jacques Merde's Avatar
Johnny2Bad,
That's not what I am talking about. I am talking about errors caused by inaccuracies in the printer paper feed and transfer mechanisms which cause subtle (and sometimes no-so-subtle) distortions of the printed image. That's why people for whom accuracy is important pay big bucks for really good hardware. With average consumer quality printers, it is more of a crap shoot.
Anyway, as I said, YMMV.
"For every complex problem, there is a solution that is simple, neat, and wrong." -- H.L. Mencken
Old 5th January 2011, 03:32 AM   #14
Jacques Merde,
You are correct an average printer is a crap shoot. I usually put reference marks in for dimension check. A decent laser jet is remarkably accurate. Okay not micro meters, but better than the naked eye or even one with a 5x magnifying glass.
Felipe,
I will work one up at lunch tomorrow. What alignment would you like?
Living Life Doing the Waltz in 4/4 meter.
Old 5th January 2011, 08:49 AM   #15
merlin el mago's Avatar
Originally Posted by SGregory View Post
Jacques Merde,
Felipe,
I will ask Kanishka & let you know, thank you very much.
Old 8th January 2011, 01:50 AM   #16
The 'Mint' protractor is the best available, if you're willing to spend the time necessary to mount a cartridge as accurately as possible. It's virtually custom made for each tonearm/table combo, allows you to use the cantelever rather than cart body to adjust zenith, and will also get azimuth as close as possible with mechanical means. Best of all, it's only 110.00, or 120.00 with a jeweler's loupe (recommended if you don't have a good magnifier). That leaves you enough money to buy a computer microscope that will allow you to adjust SRA to the usually-prescribed 2 degrees off of vertical relative to your budget for the 'Clearaudio' alignment tool. Much more info from many, many satisfied users at Audiogon. Lacking this, I'd just print an arc protractor off of Conrad Hoffman's site-free, and amazingly good.
No vested interest, blah, blah, blah, just satisfied.
Best Tractor / Arc Protractor / Mint Tractor / tonearm alignment / Yip Mint Protractor / Mintlp Protractor
Old 8th January 2011, 02:12 AM   #17
R.I.P.
Buy most any alignment tool you want, because they will only get you inthe ballpark anway.
Then read the Guru Alignment white paper and get to work:
http://www.vacuumstate.com/fileupload/GuruSetUp.pdf
Regards, Allen
overhang adjustment vs. twisting in slots ilewis33 Analogue Source 2 17th March 2009 01:55 PM
NEWBIE Q: Lowering output voltage of phono catridge soundbites Solid State 9 19th November 2007 09:49 AM
Sheet Metal Gauge kafka007 Tubes / Valves 10 15th November 2006 01:40 AM
Alignment gauge for Ortofon OM-10 Mike Davis Analogue Source 1 7th July 2004 08:29 PM
Combining different gauge wires together AJ Bertelson Parts 5 26th May 2004 04:03 AM
Copyright 1999-2017 diyAudio
