| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
I just received Cābles en kit - AUDIOPHONICS XP-OCC Kit Cāble de Modulation RCA Cuivre OCC 1m and I see now there is no magnetic shield in this kit! What do you think of that? |
#2 |
Well, unless you speak (read) French....
It seems to be a single conductor 24AWG copper wire with impossible-to-work with teflon insulation. Useful for some hi-temp industrial application. Other than that? E |
#3 |
The English term for this cable is an "rca interconnect cable." I do speak French, but (very) badly after 3 decades of disuse.
Not sure where mickeymoose got the impression the OFC wire is insulated with teflon - it states specifically that it is uninsulated. This is a kit with teflon sleeving, natural cotton tubing, and rca plugs. Not sure how much merit these interconnects have, they certainly will not tolerate a great deal of flexing. Si le kit n'est pas trop cher peut etre amusant a realize soi-meme.. Le resultat, cette une autre chose.. FWIW, there is no magnetic shield in any interconnect. Many do have an electro-static shield, aka shield - the good ones use a mesh providing a high % of shielding, the cheap ones use a spiral of untwisted stranded conductors which is not very effective IMHO. I use lots of interconnects without shielding in my system and as long as the source impedance is low generally I have not had any problems. This design should have relatively low capacitance by virtue of the teflon dielectric (tubing) and for some resistance to EMI a very mild twist could be helpful, but not necessarily what the kit designer had in mind. (Mine are mostly not twisted)
www.kta-hifi.net Last edited by kevinkr; 4th January 2011 at 03:32 PM. |
| Toroid transformer, shield or not to shield? | bays_9a5tt | Digital Line Level | 10 | 21st December 2008 02:10 PM |
| active cable shield driver in a phono amp -- does it make sense (noise- or sonicswise | Onvinyl | Solid State | 0 | 1st June 2008 09:53 AM |
| Have annoying noise?... want a diy shield... try this one. | destroyer X | Solid State | 17 | 8th October 2005 10:52 AM |
| Cable shield grounding | Prune | Parts | 1 | 20th December 2003 01:28 AM |
| Shielded cable for internal amp wireing: where do I connect the shield? | Bricolo | Parts | 11 | 26th June 2003 01:26 AM |
| Page generated in 0.08607 seconds (73.70% PHP - 26.30% MySQL) with 10 queries |
