Thorens TD124 measurements - Page 3 - diyAudio
Old 17th January 2011, 08:07 PM   #21
kevinkr's Avatar
Originally Posted by Pano View Post
Yes, agreed. If we could turn back the clock a bit and get some before and after measurements of Kevin's work, that would be cool. Maybe on his next victim.
It'll be a quite while I think before the next victim arrives.. The tables I am currently working on are not in situ and I have no baseline information for them either.
When I got mine there would have been plenty of 120Hz hum due the locked rotor, but the table as it stands is gratifyingly quiet.
The zamac platter rings badly, and is also excited by the idler to a limited extent - neither are things that the iron platter does to any comparable extent. Mine is isolated from the record by geltec dots, and a Merrill-Scillia mat.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 18th January 2011, 03:15 PM   #22
genel is offline genel  United States
Default Platter
Kevin,
I too, decided to remove my Zamac platter for the same reasons. It rings like a bell. I still have it, but who knows, perhaps I will sell it some day.
I've been seeing the original cast iron platters on ebay lately, why don't you get one? a LOT cheaper than the Schopper made of "unobtainium" and that would give you a good baseline. Also, I'm sure you could sell it easily if you wanted to.
Check this out:
THORENS TD124 PLATTER PARTS - eBay (item 150547826816 end time Feb-11-11 11:32:56 PST)
http://cgi.ebay.com/Thorens-TD-124-M...item3a62596d4b
Good luck!
Old 18th January 2011, 04:15 PM   #23
kevinkr's Avatar
Originally Posted by Geneml View Post
Kevin,
Check this out:
Thorens TD 124 Main Platter - ORIGINAL Top Condition!!! - eBay (item 250758131019 end time Jan-25-11 12:40:36 PST)
Good luck!
Hi Gene,
I've avoided the stock iron platter until now because I use an MC cartridge with strong magnets. I do know it is possible to compensate for this issue and may indeed get a stock cast iron platter at some point. For now the budget is focused on the Schick acquisition..
Old 5th February 2011, 03:52 AM   #24
Default Sucess, finally!
Kevin, (and some of you)
If you remember, I partially broke the spring steel band (at a hole) that shifts the transmission, (cam.)
After many dead ends, I have it fixed, (hopefully forever.) I took it to a jewelry repair place, and they silver soldered the break. All seems to be well, but I worry for the long-term.
Gene
Old 5th February 2011, 04:05 AM   #25
kevinkr's Avatar
Well that's good news that it is fixed, hopefully it will stay that way.
Old 5th February 2011, 07:31 AM   #26
volken is offline volken  Netherlands
You can order a new one at Schopper if it fails !
When a Kenwood record cleaner-to be becomes a Garrard 301/Thorens TD124 Hybridmonster happycat Analogue Source 40 4th August 2015 07:27 AM
Thorens TD135 / TD124 Capacitor Query bluetomgold Analogue Source 3 8th October 2005 05:16 PM
TD124 pitch control Tee-Rex Analogue Source 11 3rd May 2005 08:55 AM
Thorens TD124 mk11 jonnypotter Swap Meet 3 8th September 2004 02:14 AM
Platter mat for TD124 turntable. ashok Analogue Source 3 19th March 2004 02:20 PM
Copyright 1999-2017 diyAudio
